Battery recommendations
Morning all,
Had a feeling my battery was on its way out after a lack of start up power and then having to jump start it the other morning. This morning again it was totally flat.
Can anyone recommend me a battery for it?
- Surrey Sam
Re: Battery recommendations
OEM Audi battery is manufactured by Varta, their equivalent model is the Silver Dynamic 610 402 092.
I think that I got mine from Amazon for about £95, if I remember correctly.
Thank you. I will have a search now. I was looking at a Varta battery anyway... http://pages.ebay.com/link/?nav=item.vi ... 0570279511
Cheers Sam. Ordered one through the Tayna website
http://www.tayna.co.uk/610-200-Varta-Si ... P3200.html
- Surrey Sam
Divine wrote:Cheers Sam. Ordered one through the Tayna website
No problem, nice little saving there over the eBay one
Defiantly cheers. It's gone up on Amazon also to £135 now.Surrey Sam wrote:Divine wrote:Cheers Sam. Ordered one through the Tayna website
- Surrey Sam
I see what you mean. Mine came from the Battery Megastore via an Amazon listing, just checked their own webside and it is £95 inc delivery. Just goes to show that you have to shop around. They're hefty buggers to lift in and out, so if you have a 'glass back' be careful.Divine wrote:Defiantly cheers. It's gone up on Amazon also to £135 now.Surrey Sam wrote:Divine wrote:Cheers Sam. Ordered one through the Tayna website
Thanks for the heads up, my back is a nightmare so I will be careful
- RossDagley
- Top Gear
I have the same battery now as above. With a new starter motor a month or so ago, it starts amazingly well!
Previously:
Previously:
That's good to know. Mine needs some more power on start up. Currently it has a piddly battery fitted, no wonder it's had it.RossDagley wrote:I have the same battery now as above. With a new starter motor a month or so ago, it starts amazingly well!
- PetrolDave
I bought a Varta H15 AGM battery online from Puredrive http://www.puredrivebatteries.co.uk/h15 ... ttery.html which is the same size but has higher capacity (105Ah) and high cold starting current (950A), yes it's a few more pennies but it's a beast of a battery.
- Surrey Sam
At face value it seems quite a bit more expensive and slightly inferior to the one linked earlier Dave, it does have the same 950 CCA which is what you need at this time of year.
- PetrolDave
Having checked both links above I can't agree that it's inferior; yes it's only 105Ah vs. 110Ah, but the CCA is 950A vs. 920A and as an AGM battery it is better able to cope with repeated heavy loads http://batteryuniversity.com/learn/arti ... ss_mat_agmSurrey Sam wrote:At face value it seems quite a bit more expensive and slightly inferior to the one linked earlier Dave, it does have the same 950 CCA which is what you need at this time of year.
Great service from Tayna batteries. The new Varta has done the trick.
Old vs. new
[URL=http://s228.photobucket.com/user/
woz2k/media/Audi%20RS4/3AE21B30-6B0B-4D78-A19F-BE75DAD312C0_zpsiulzrhff.jpg.html]
[/URL]
Old vs. new
[/URL]- Surrey Sam
Thanks for the link Dave, had a feeling there maybe more to it than face value specs. That site has a lot of info there to try and take onboard, so now bookmarked.PetrolDave wrote:Having checked both links above I can't agree that it's inferior; yes it's only 105Ah vs. 110Ah, but the CCA is 950A vs. 920A and as an AGM battery it is better able to cope with repeated heavy loads http://batteryuniversity.com/learn/arti ... ss_mat_agmSurrey Sam wrote:At face value it seems quite a bit more expensive and slightly inferior to the one linked earlier Dave, it does have the same 950 CCA which is what you need at this time of year.
Good job Divine
The old one looks tiny, so quite possibly under rated as well.
Users browsing this forum: No registered users and 243 guests
