Flat tyre light on, but no flat tyre??
ChrisW
Post by ChrisW » Thu Jan 29, 2015 8:13 pm
My car is telling me I have a flat tyre, but upon checking all the pressures all are at 31psi?
Is one of my tyre pressure monitors goosed?
Current: 07' B7 RS4 Avant
Previous: Mk2 Golf VR6 conversion, Mk2 Golf GTi 16v, Mk2 Golf 1.6 GL Auto, Mk3 Golf R32 conversion, BMW Z4 Coupe, BMW 430d, Audi S3, Defender 90 XS, Alfa Romeo 145
rwilsonrs4
Re: Flat tyre light on, but no flat tyre??
Post by rwilsonrs4 » Thu Jan 29, 2015 9:19 pm
yeah likely is a sensor battery flat or faulty , try and reset the pressures on the DIS , maybe one of the pressures was higher when you last entered them ? it , i have done that before but not making them all the same as the hose wasn't long enough and just did the one that was a bit low
:bigblink:
1/4 mile 12.01 secs 123.5mph
Post by MikeFish » Thu Jan 29, 2015 9:21 pm
If the battery or sensor goes don't you get a different symbol than if the tyre is flat? I seem to recall a flat yellow symbol for low pressures or a red one with a cross through it for no communication?
ChrisW
Post by ChrisW » Thu Jan 29, 2015 9:42 pm
Ive got the yellow flat tyre picture, i'll see if its still doing it in the morning and reset it if it is, thanks guys :)
Cerec1
Post by Cerec1 » Thu Jan 29, 2015 9:53 pm
MikeFish wrote:If the battery or sensor goes don't you get a different symbol than if the tyre is flat? I seem to recall a flat yellow symbol for low pressures or a red one with a cross through it for no communication?
Mine went from yellow for low pressure at the time of a puncture to red fairly rapidly when the tyre was completely flat.
Had to do a reset when I fitted my winter tyres and wheels cos the system was registering low pressure when all was fine.
nij
Post by nij » Fri Jan 30, 2015 3:53 am
31psi seems a bit low. The manual recommend 38psi at the front and 35psi at the rear. With the cold weather we're getting at the moment, you're tyres will need pumping up as the pressure will be lower than what it was in the summer.
My yellow tyre warning came on last week for the very same reason, it was about 32psi when I normally have it on recommended pressure.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
rwilsonrs4
Post by rwilsonrs4 » Fri Jan 30, 2015 5:46 am
i get a yellow for a slight loss one my right rear and its usually around 30 , when i don't drive it for 2 weeks while away it comes up red and the pressure is around 26 psi as i have a slight rim leak , i blow the tyres up to 35 and reset it , so red with the cross through it doesn't mean no comms? i reckon is excessive loss compared to stored pressure or a rapid loss obviously like when a punter happens
ChrisW
Post by ChrisW » Fri Jan 30, 2015 7:46 pm
What you are all saying computes, as this is the first time in my ownership where we've had some really low temperatures. I'll put some more air in them tomorrow.
thanks guys :)
ChrisW
Post by ChrisW » Fri Feb 06, 2015 5:00 pm
So I have a development on this. All tyres are up to correct pressure, but now I'm getting the red animated check your tyre pressure symbol? I can't access the menu to reset my tyre pressures as this red monstrosity is plastered all over the DIS.
Is it time to check the pressure sensors at the garage?
Users browsing this forum: No registered users and 309 guests
