Exhaust options on DRC menu
Hi All
Please be gentle as this is my first post. Picked up my new to me RS4 at the weekend. Its a 2013 model in Sepang Blue with Sport Pack and V Spokes and Tech pack. We tried a demo car at our local dealer and noticed that ours hasnt got a separate option to turn the sports exhaust on or off. Mine has the sport pack and the exhaust not changes when you select Dynamic in the engine options but not indepentend exhaust option which was at the bottom of the list on the demo car. Is there a software upgrade?
Mark
Mark
Current- 2013 B8 RS4, Sepang Blue,
Past BMW 135i Coupe
Past BMW 135i Coupe
Re: Exhaust options on DRC menu
I think this might be a facelift vs pre-facelift difference.
- Graeme4130
Correct, it came in with the model year facelift
However, if you select engine dynamic in individual, you should activate the louder exhaust option
When you start the car, it'll always be in the 'valves closed' position, but will open and stay open once you hit the gear stick to S rather than the default d, and should remain open when you return it to D
Hope that makes sense
Although this is not consistent either..... Mine is a face-lift and I have to change the driver mode out of and back into Individual to retain valves open (Dynamic). It's with Audi at the end of the month for some other bits and pieces and I have asked them to get a definitive answer...
B5 S4 Avant
R8 V8
B7 RS4 Avant
B8 RS4
R8 V8
B7 RS4 Avant
B8 RS4
Mines facelift, I've been messing today trying this out as per the other thread about this issue.
In individual with exhaust set to dynamic it's still not as loud as when you select S in the gearbox as everyone suggests.
Mine though seems to close valves when D is selected though I'm sure.
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
Thanks for the info!
Past BMW 135i Coupe
Past BMW 135i Coupe
Mine is the same, all a bit confusing as I have it set to dynamic but the note changes when I switch to sport and I had thought that it would be loud at all times under that setting. It then seems to quieten again when I go back to D.Macdaddy wrote:Mines facelift, I've been messing today trying this out as per the other thread about this issue.
carsarecool
More discussion here - viewtopic.php?f=61&t=113163&p=714457&hi ... st#p714457
- Vodkaking77
What are the main differences between B8 and B8.5??
The biggest is about a half, sometimes .5
It depends on the factory the car was built in.
It's all torque talk.
In all seriousness, electric boot closer as standard & a couple of other things, but they were priced in rather than the car being a higher spec for the same £
Ive started a thread here...Vodkaking77 wrote:What are the main differences between B8 and B8.5??
viewtopic.php?f=61&t=113454
'15 B8 RS4 - SOLD
Users browsing this forum: No registered users and 187 guests
