new owner my RS4 ;)
Re: new owner /member
I think a few of the SS+ suspension guys run 8mm all around to ensure there is no rubbing at the rear, but as per AdrianD's thread I posted above he's also running the 8mm F, 10mm R combo.
Think Sam might run spacers and has SS+ so may be able to confirm his set up too.
- Surrey Sam
Spot on Marc
Yes, I have run 8mm front and 10m rear spacers this summer with SS+ suspension. The rears have rubbed a few times, mainly on fast B-roads where larger compression happens and over big speed bumps. I will be changing the rear 10's to 8mm and hopefully solve the issue.
8mm it is then so were talkin 5x112 ? thats if i decide to take the first step lolSurrey Sam wrote:Spot on Marc![]()
Yeah i think tyres play a part of it as well... since changing to Goodyears I do now get the occasional rub... but it's not enough for me to change to 8pm as it's so rare...
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
8pm.. darn auto correct lol... i obviously meant 8mm
2010 911 Turbo PDK.
Yep 5 x 112. I'd recommend buying from Virdee the forum sponsor. If you ring him, tell him you've got a b7 rs4 with SS+ suspension he'll make sure you get the right kit. Saves on aggro later buying inferior stuff or even other quality branded stuff that has still caused many forum members headaches.andyg72 wrote:8mm it is then so were talkin 5x112 ? thats if i decide to take the first step lolSurrey Sam wrote:Spot on Marc![]()
- geordie jay
- 5th Gear
knew it wouldn't be long before you were modding
lets call my mods " minor mods " no biggies here lolgeordie jay wrote:knew it wouldn't be long before you were modding
We're here to 'encourage', hey Jay?! Lolgeordie jay wrote:knew it wouldn't be long before you were modding
- geordie jay
- 5th Gear
hell yeah!!! stick a supercharger on with your spacers
Sorry I don't do FI
+1, many have tried to source from elsewhere and end up here with spacers that are i'll fitting or vibrate etc. Stick with Virdee or Revolution, they both know the car well and know the right type of spacers to supply you.marc1 wrote:Yep 5 x 112. I'd recommend buying from Virdee the forum sponsor. If you ring him, tell him you've got a b7 rs4 with SS+ suspension he'll make sure you get the right kit. Saves on aggro later buying inferior stuff or even other quality branded stuff that has still caused many forum members headaches.andyg72 wrote:8mm it is then so were talkin 5x112 ? thats if i decide to take the first step lolSurrey Sam wrote:Spot on Marc![]()
Andyg72 what area are you based?
Luke I'm in South staffordshire why would you askLukes3 wrote:Andyg72 what area are you based?
Great
think im your neighbour lol.
Blue saloon if you see me around
Users browsing this forum: Google [Bot] and 153 guests
