Corrosion warranty help required
- SimonS4MTM
- Top Gear
Hi all
Took a trip to my local dealer today to check if some corrosion was covered under warranty. A small bubble on the boot handle (the bit with the lock).
Was told that this was not covered as it is a trim piece.
I have searched the forum and found that some people have had this work carried out under warranty.
Can you help me out guys with an ammo list to take to my dealer to get this sorted.
Cheers in advance
Cheers in advance
RE: Corrosion warranty help required
Hi ,let me know how you get on as mine has done the same thing . grizz
Unit 20
0151 3366888
0151 3366888
Guildford Audi replaced mine under warranty, after initially telling me it was a trim piece.
A few others have also had theirs replaced by Guildford Audi, and if I recall coreectly Thomson has had his done too.
Explain to them that it is painted to the body colour, and is a known faulty part.
tell the dealer to contact the warranty claims department rather than making the rules up themselves.
Good luck !
Good luck !
Too many toys, not enough time
- SimonS4MTM
- Top Gear
Cheers John,
abyone else had theirs done
Hi - I am the second owner of mine and I understand that the first owner had the same problem with a small amount of rust on the tail gate. If you PM I can send you the Reg and you can have a chat with the Dealers to see what was done. If not I can try and find out but I am sure that it was covered but it was in the early years of teh car's life.
Robert.
Robert.
Simon, if it helps, the bubble on mine was about an inch to the left of the lock, on the top edge.
I had this problem on my old S4 and sg smith audi said it wasent covered, But i tought paint was covered for 5 - 10 years
Past: Noggy 2000 B5 S4
Azure Blue 2000 Oettinger B5 S4
Mugello RS6 *STOLEN* RN52 UXB
Avus Oettinger A3 2.0T
Misano Oettinger C5 RS6
Phantom Oettinger C6 A6 Sline Avant
Present: RS7 Panther Black
Porsche Cayenne
C7 Avus silver avant 2.0 tdi ultra
Porsche Cayenne
As posted above I got mine sorted. What they wouldn't do though was the little black painted triangle at the back of the rear door glass. Mine has a stone chip on it, and this IS classified as a trim piece according to the warranty guys. To replace it requires the entire door to be stripped down
- SimonS4MTM
- Top Gear
As my car is a personal import, I decided it was not worth the hassle of even trying to get mine done under warranty. I bought the trim from VAGPARTS for about £20 and had it painted for just under £100. I haven't fitted it yet though.
2001 Silver S4 Avant
Simon, any news on this? I've got exactly the same thing on my 2000 S4. Each side of the boot trim is starting to blister. So is the small quarter panel on the rear door. I took the car in to the dealer, who said that although strictly speaking it's not covered because it's trim, it might be covered because the corrosion could spread to the main metal!! They suggested I speak to Audi Customer Services in Walsall. I spoke to Customer Services and they asked that the dealer pass the matter to Audi Warranty Claims in Milton Keynes. If rejected, then Customer Services would take a view. I'm waiting for a response from Warranty Claims at the moment.
Have to say I was shocked to read of so many others with the same problem. I'm the second owner and just assumed that the first owner had had a slight knock and fettled it back up. A class action might be in order!
- SimonS4MTM
- Top Gear
Claim rejected by Audi Warranty as expected. Will now go back to Customer Services to cause a commotion.
In a telephone conversation with Audi Bodyshop, they admitted this is a known defect. The process of fixing the boot trim to the boot lid cracks the paint and over time can lead to corrosion, they said. So there must be a design lack of fit between the trim and the parent metal.
I did a quick survey at the car park I use and found three other B5's of 99/00 registration. All three have got rust bubbles on the boot. It's evidently not just for aesthetic reasons that they designed this trim out on the B6 and B7 models.
