Like topic says, i miss fire in the cylinder 2. The car was on a service and had the timing belt changed and New oil in the engine.
Drove home and everything is fine. Next day it's bad and i let it stand still to Next day. then it's suddenly fine and until some days- then it's bad again.
the first time it happened it smelled gasolin very Heavy.
Drove it to workshop and they said this:
Plugs and coil is checked fine. Wires is fine. They will perform a compression test Next week to check engine.
this is very strange, anyone have this problem?
AHK engine 4,2.
S6 plus cylinder 2 misfire
S6 Plus Avant 1997
Re: S6 plus cylinder 2 misfire
compression on engine ok.
switched Place on the ignition conrol modules and the fault code moved. So i have ordered a New ICM.
UPDATE: Problem solved, New ICM.
S6 Plus Avant 1997
