Loud Air Noise on Boost
RS6_Drew
Post by RS6_Drew » Fri Dec 05, 2014 7:45 pm
Hi Guys,
Wonder if anyone can point me in any sort of direction to look.
So normal driving, off boost is quiet, and wouldn't think there is an issue. On boost I can hear a loud constant release of air, so I'm thinking a hose relating to one of the turbos has split. (More power/boost, more air noise)
1. Do you think I am right in this assumption?
2. Are they any known "weak spots" with pipes that I should check first, or is it a case of checking all?
Any advise is better than I have at the moment.
RS6's are a bit of an unknown for me - owner for a year only.
Thanks All in advance.
Drew :)
Re: Loud Air Noise on Boost
Post by Shoppinit » Fri Dec 05, 2014 9:23 pm
Probably the bottom hose has popped off. Very common. Easy fix. Needs to be fixed asafp.
RS6_Drew
Post by RS6_Drew » Fri Dec 05, 2014 10:10 pm
When you say, bottom hose, are you referring to the bottom hose from the intercooler I assume?
Is it easy enough to get to from underneath?
Drew
Post by Shoppinit » Fri Dec 05, 2014 10:23 pm
Yup. Easy enough if you can get the front in the air. Just drop the sump guard.
RS6_Drew
Post by RS6_Drew » Fri Dec 05, 2014 11:23 pm
Great - thanks - I'll have a look tomorrow.
Drew
audiacious
Post by audiacious » Thu Dec 11, 2014 3:46 pm
Shoppinit wrote:Probably the bottom hose has popped off. Very common. Easy fix. Needs to be fixed asafp.
ASAFP. I can vouch for that!
