LED headlight condensation
Chickster
Post by Chickster » Thu Nov 27, 2014 10:49 am
I recently took delivery of a new RS6 and as you'd expect it's terrific. However, there is on thing that took me by surprise - the fact that the LED headlights are very prone to condenstation this time of the year. Has anyone else experienced this issue? Apologies if it has been discussed before. I've had it since day one and has not cleared. Attached is a pic.
headlight
rabies
Re: LED headlight condensation
Post by rabies » Thu Nov 27, 2014 12:13 pm
I've had this on occasions - notably when the car has been washed using a pressure washer
Chickster
Post by Chickster » Thu Nov 27, 2014 1:03 pm
Have you the same headlights and have you had it the last few days? You in UK?
RSphantom
Post by RSphantom » Thu Nov 27, 2014 2:13 pm
I have the same problem on mine as you do. I seems to happen after washing but also after driving in damp/wet conditions. The heat of the engine seems be a contributing factor. However, it never happened on my first one but that was during the summer period so that might have something to do with it. I just looked at mine and its not been driven today and no condensation but its raining here. I'm going out in it later so I'll check after that. I'm not overly concerned as its the same on both which indicates there are no cracks in the lights :beerchug:
2019 RS3 4 door - Gone
Chickster
Post by Chickster » Thu Nov 27, 2014 2:18 pm
I have spoken to the Audi dealer today and he says it's "normal". The headlights are vented and so allow moisture in and it's something to do with the difference in temperature between the back of the headlight and the the perspex at the front, which causes condensation. Not a warranty job.
RSphantom
Post by RSphantom » Thu Nov 27, 2014 2:21 pm
Chickster wrote:I have spoken to the Audi dealer today and he says it's "normal". The headlights are vented and so allow moisture in and it's something to do with the difference in temperature between the back of the headlight and the the perspex at the front, which causes condensation. Not a warranty job.
Sounds like a good excuse :bigblink:
M1R XE
Post by M1R XE » Fri Nov 28, 2014 12:18 am
Hi guys this seems like a rare occurance on all new cars not good at all. My friends new RR sport same thing, new e63 amg same thing and so on most new cars in past few months i have noticed this. Not acceptable at all but whats causing it if on so many new models ?.
Chesterfield
Post by Chesterfield » Fri Nov 28, 2014 12:57 am
Same on the F430 I had. Maranello rejected it on warranty too.
DragonRR
Post by DragonRR » Fri Nov 28, 2014 1:29 am
I had the same thing with my M5 a couple of years back with one headlight. I too was told that the lights are vented but they still replaced it since only one light seemed to have the problem.
Polo 895cc 81|Datsun thing 83|Astra Van 1.3 85|Escort 1.6 87|XR2 88|Renault 5 Trbo 90|Renault 21 Trbo 93|XR2i 16v 94|Jag XJ6 99|BMW M3 E36 01
BMW 328i E46 04 & Honda VFR750|BMW M3 E46 06|Jag XK8 07 & Honda CBR600RR|BMW 645CSI E63 08|BMW M6 E63 09|Audi S5 10|BMW M5 F10 12 blk
Audi RS6 C7 14 Dayt Grey|Vxhall Corsa 1.2LE Yell|Golf R 15|C63s Ed 1 Coupe|Porsche 911 991 Turbo S 14 Saph Blue|RS6 PE 16 Nogaro Blue|AMG GTS 16 Blue|M5 Comp White 18|Current: M5 Comp Snap Blue 19|Audi R8 V10+ Blk 18
VARSITY
Post by VARSITY » Mon Dec 01, 2014 11:21 am
I would look at using a different dealer.
Thats a poor excuse and one thats not acceptable.
Never argue with an idiot, they will drag you down to their level and beat you with experience.
wildbore
Post by wildbore » Tue Dec 02, 2014 8:52 am
Misting up of the headlights is specifically stated in the owner's manual as being a normal occurrence, so it is almost inconceivable that Audi will swap the units at their cost. The very reason that it is mentioned in the owner's manual is to preempt any possible waranty claim.
jezitalia
Post by jezitalia » Tue Dec 02, 2014 10:02 am
I was told the same by my dealer and the condensation goes when the heat from the lamps burns it away. told no problem for electrics, its normal.
feeltheburn
Post by feeltheburn » Tue Dec 02, 2014 6:16 pm
The same thing happens on my LED lights- it happens when I have just washed the car. Also saw it 5 or 10 minutes after stopping following a long drive in the rain. My previous A4 and the one before that (B8 & B7) both had Xenons and condensation formed on those lights, as did the 4 or 5 Passats I had before that. It was explained to me a while ago by VW, when I "complained", that this was normal and the lamp housings were essentially self breathing at the rear to help with heat dissipation.
I was concerned that the condensation could lead to mould forming in the lights later in the life of the car. This never happened to any of the light housings while I had the cars. I had my last A4 For 4 years, washed it regularly and the light housings remained pristine inside. So I have not mentioned the condensation on the RS6 LEDs to the dealers as I am pretty satisfied that it is normal. My wife's Q5 does the same, but again the light housings are still pristine.
So I wouldn't worry at all about it ...ignore the Audi bashing...and enjoy, what is, a truly fantastic car.
RS6 C7 (2014), Daytona Pearl, 21" Titanium, On Air, LEDs, Sports Exhaust, Dynamic Steering, Red Calipers, ACC, Top View, Connect, Tints, Rear Side Airbags, Rear heated seats; MP4S
W8PMC
Post by W8PMC » Tue Dec 02, 2014 9:57 pm
Doesn't happen on M5's :audibash: :beerchug:
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
VARSITY
Post by VARSITY » Wed Dec 03, 2014 4:38 am
feeltheburn wrote:The same thing happens on my LED lights- it happens when I have just washed the car. Also saw it 5 or 10 minutes after stopping following a long drive in the rain. My previous A4 and the one before that (B8 & B7) both had Xenons and condensation formed on those lights, as did the 4 or 5 Passats I had before that. It was explained to me a while ago by VW, when I "complained", that this was normal and the lamp housings were essentially self breathing at the rear to help with heat dissipation.
I am at a loss as to why people accept these excuses.
The lights on our 1 year old Q7 were changed to a newer design with better rear breathers, the C7 RS6 lights have also been changed. So I wonder why we have been treated so differently?
As for Audi bashing, well I would say thats not exactly the case, I just think spending the kind of money each year we loyally do with the brand that the products should be perfect, not just acceptable.
Users browsing this forum: No registered users and 65 guests
