As I assume you know, on this engine you depress the clutch pedal and then press the fob into the dash in order to start the car, Recently, on occasion, the engine has refused to start (or engage even), I thought that perhaps I just was not depressing the clutch pedal fully, but I was not getting the 'to start the engine depress the clutch pedal' message on the dash. On taking the fob out of the dash and waiting a minute or so it will then start as it should. I have been having to depress the clutch pedal fully, and I mean to the floor, for some time, in order to be sure of the car starting. No issue at all with the clutch operation itself, only with this starting procedure.
Anyone had this occur? Any adjustment on what I assume is a sensor for the clutch pedal movement?
All help appreciated as always.
