Got the car booked in at audi, did a bit of googling and found that the thermostat is prone to failing.
If the thermostat has failed and apparently they fail closed
I have visually checked for the new water pump and it looks like it has been done, no coolant level drop yet but a closed thermostat would not do that.Ian_C wrote:Aren't the early cars prone to water pump failure? The water pump was upgraded pretty soon into S4 production? And yours is a 2009 iirc?
I think there might be a workshop recall for the water pump and then a separate one for the thermostat.
Maybe check the coolant level before you set off, if its dropped then get it picked up by Audi.
