Wet carpet on passenger side footwell
Patgas1
Post by Patgas1 » Sun Oct 12, 2014 4:12 pm
Had some serious rain here last week and not used car,give her bit of clean out today and noticed wet mat on passenger side,not sure if it looks like it has been running down bottom left plastic kick panel aaaaaaaaaaaa
Help
boombastik
Re: Wet carpet on passenger side footwell
Post by boombastik » Sun Oct 12, 2014 4:20 pm
If your prone to parking in areas where there is a lot of trees you can often find the scuttle panel under the bonnet blocked with leafs which can cause the water to leak in to the cabin, this happened with my mates A4 all road
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
Patgas1
Post by Patgas1 » Sun Oct 12, 2014 5:08 pm
Just took a look and no leaves.......but after investigating I'm pretty sure due to fact the car was parked on slight incline and the amount of rain I think the water has built up too much to exit out of the side drain hole and backed up and gone under the polen filter housing that's sealed from the cabin with a poxy bit of foam.......not even a proper seal what a piss poor design from audi :( shocking ......carpets soaked mat took most fortunately and full of electrics under that side bloody hell.
Patgas1
Post by Patgas1 » Sun Oct 12, 2014 6:35 pm
Any one else had this issue
Audi Pardner
Post by Audi Pardner » Sun Oct 12, 2014 6:54 pm
I seem to remember a thread some time ago on here where someone had a problem like yours and it was the T-piece take off for the rear screen wash. Can't be certain, sorry.
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
rocket1
Post by rocket1 » Sun Oct 12, 2014 7:36 pm
have you got a sunroof ?, if you have then sometimest he drain holes can block and the water will find its way to the car.
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
Patgas1
Post by Patgas1 » Sun Oct 12, 2014 7:50 pm
Havnt got rear screen wash ?
And yes do have sunroof ....I have blown holes out with air line but I'm 99% sure it's what I mentioned above .....there isn't a seal between pollen filter house an body just a foam dust seal.
Audi Pardner
Post by Audi Pardner » Sun Oct 12, 2014 9:41 pm
Patgas1 wrote:Havnt got rear screen wash ?
Ah, sorry - I was obviously thinking Avant :roll:
Patgas1
Post by Patgas1 » Sun Oct 12, 2014 9:47 pm
I will pull it off tomorrow and see if I can seal it better as I caught it just in time or could have been costly
davers6
Post by davers6 » Mon Oct 13, 2014 4:20 pm
Had this on 2 m5's and a c5 rs6 always park facing downhill can't happen then :biggrin3:
rob-carp
Post by rob-carp » Wed Oct 15, 2014 9:47 pm
Hi
Had it on mine, passenger side front carpet wet, watched the water trickling down the plastic trim in a heavy downpour tracked it down to windscreen seal on passenger side, shoddy workmanship when the windscreen was replaced , all sorted now,
docurley
Post by docurley » Thu Oct 16, 2014 5:21 pm
There are two drain points in the scuttle panel and silt can plock them up, get a old school coat hanger and straigten it out then poke the holes.
They tend to have a gromit in there and most people just poke them out also a incorrectly fitted pollen filter cover can also cause this issue.
Rick_RS4
Post by Rick_RS4 » Thu Oct 16, 2014 6:38 pm
my missus usually has a wet carpet after shes been in the RS with me too
Users browsing this forum: Majestic-12 [Bot] and 150 guests
