RS6 useful info and links
Re: RS6 useful info and links
Oil Change Intervals for the ZF 5HP Series of Transmissions, by ZF...
http://www.youtube.com/watch?v=Si8HXqpgz9A
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
DIS LCD Repair.
- Attachments
- DIS LCD Repair High res.pdf
- (4.61 MiB) Downloaded 196 times
Yellow Koni's
Yellow Koni's
Yellow Koni's
Yellow Koni's
Yellow Koni's
Yellow Koni's
I don't understand anything in that last link. I can't get any useful info out of it at all. Am I being thick?
+1Shoppinit wrote:I don't understand anything in that last link. I can't get any useful info out of it at all. Am I being thick?
Whilst on the subject has anyone got either this
http://www.ebay.co.uk/itm/331307913667? ... EBIDX%3AIT
Or the cd version.
Are either any good ? I would prefer the book unless the cd is better.
Or the cd version.
I believe it's very similar to Elsawin. Both will be good references for any job.
Elsawin is cheaper to buy through eBay but it's a little more difficult to get setup for the first time, although if you read the instructions carefully you'll be fine.
Thanks I will have a look at both options . Are they both aimed at the trade or DIYers?
Pete, I went for the eBay copy of Elsawin.. Yep little tricky to setup, but very useful tool.. Will be using to reference my IC's replacements & one way valves changes 2
But it doesn't work with Windows 8.1. Or at least, not with mine.
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
Works with a virtual machine though.
yep, VMWare for example, running xp on it, job done.Shoppinit wrote:Works with a virtual machine though.
Yellow Koni's
Yellow Koni's
Went for the Bentleys hardback option in the end, mainly due to a major case of computer incompetence on my part. Oh and a state of the ark computer.
It arrived today and having studied it at length I can confirm it's definitely a book full of words, pictures and other technical sh*t!
Just thought I'd post to help others make up their minds which to get.
