Tumble flaps
RS4_Ollie
Tumble flaps
Post by RS4_Ollie » Sat Sep 13, 2014 7:19 pm
Hi, Im going to do a carbon clean soon and was reading a lot of people remove the tumble flap.
What are the pros and cons of doing so?
:beerchug:
coffey555
Re: Tumble flaps
Post by coffey555 » Sat Sep 13, 2014 8:16 pm
Better airflow but slight loss of torque at lower rpm I believe.
I left my ones in after my carbon clean as there was no play in them.
Wiki says the tumble flaps are there to assist low engine speed combustion.
Misano Red RS4 B7 Avant
RossDagley
Re: Tumble flaps
Post by RossDagley » Sat Sep 13, 2014 11:03 pm
It runs a little more lumpy on part throttle openings, especially when cold. But the benefits are less restriction and less to gum up/go wrong!
Previously:
adsgreen
Re: Tumble flaps
Post by adsgreen » Sun Sep 14, 2014 12:39 am
The tumble flaps simple close off half of the intake path leading to the cylinder. As it's low rpm this isn't a restriction but does have the effect of increasing the velocity of the air into the chamber so when the fuel is injected it can mix up a bit better.
If properly mapped there is no loss in power but will hit economy by a couple mpg when just pootling about
RS4POWER
Re: Tumble flaps
Post by RS4POWER » Sun Sep 14, 2014 5:31 am
In order for you to remove the tumble flaps you will have to punch out the freeze plugs. There is a company out there that recommends reusing them by applying loctite upon reinstall but I strongly suggest you don't. New freeze plugs can be sourced (not by Audi) but you'll have to dig a little bit. PM me if you need them.
I have been running a deflapped p/p IM for years now with no adverse effects. Highest g/s I saw was 174 per bank. I believe with a tune that removes the tq limiter and considers less manifold restriction, p/p would tie in nicely. Perhaps Doug from MRC can chime in on this. :bigwave:
If anyone here is looking for a port/polished, deflapped IM (work performed by silverrs4) PM me, I have a spare one for sale.
skydude
Re: Tumble flaps
Post by skydude » Sun Sep 14, 2014 1:36 pm
I used a very small ratcheting wrench with a very short torx bit to remove flaps without touching the freeze plugs. Had them all out in 30 minutes
RS4_Ollie
Re: Tumble flaps
Post by RS4_Ollie » Sun Sep 14, 2014 8:59 pm
If they aid low down torque I think I'll leave them in as it's a little lacking in the low torque dept.
:beerchug:
RS4POWER
Re: Tumble flaps
Post by RS4POWER » Sun Sep 14, 2014 11:39 pm
SkyDude wrote:I used a very small ratcheting wrench with a very short torx bit to remove flaps without touching the freeze plugs. Had them all out in 30 minutes
This is good to know.
Re: Tumble flaps
Post by bam_bam » Sun Sep 14, 2014 11:42 pm
Haha, flaps...
hlbeckley
Re: Tumble flaps
Post by hlbeckley » Mon Sep 15, 2014 5:08 am
coffey555 wrote:Better airflow but slight loss of torque at lower rpm I believe.
Hmmm I have a different view, I had low end torque pick up, albeit ever so slight
It is a bit lumpy below 3k revs when cold
The power gains post de flap and carbon clean are really very noticeable
No error codes yet either, I vote do it and add I take spacers too at same time
PetrolDave
Re: Tumble flaps
Post by PetrolDave » Mon Sep 15, 2014 5:46 pm
hlbeckley wrote:The power gains post de flap and carbon clean are really very noticeable
Was the power gain due to de-flapping, carbon cleaning or both?
If you did them both at the same time then it's impossible to tell, but anecdotally carbon clean is worth c. 30bhp.
hlbeckley
Re: Tumble flaps
Post by hlbeckley » Mon Sep 15, 2014 7:45 pm
Both same time but driven a de flapped post CC and flaps in, delivery is very different
Users browsing this forum: Google [Bot] and 166 guests
