Spongey brakes
JohnW
Re: RE: Re: RE: Spongey brakes
Post by JohnW » Thu Feb 24, 2005 2:03 pm
Scotty wrote:I agree with what you're saying but if it's a closed system where would the moisture come from?
p.s. This is my attempt at searching the web!! :wink:
Good effort ! :lol:
The system is not fully closed. It cannot be to allow for both fluid movement when you apply brakes and as the pads wear down.
When the fluid overheats it doesn't just overheat the bit at the calipers, it overheats the whole lot that is under compression in the fluid line.
The moisture is absorbed by the fluid through the cap on the
reservoir. This cap has a small breather hole. This is why it is advised fluid be changed every 2 years.
On some bikes the reservoir caps have a rubber membrane that
acts as a diaphram and sits on the top of the fluid to keep it seperate
from the air.
For some reason cars don't seem to do this though (maybe its the amount of fluid level travel required).
Too many toys, not enough time
Scotty
RE: Re: RE: Re: RE: Spongey brakes
Post by Scotty » Thu Feb 24, 2005 8:30 pm
Cheers.
See. 'Searching' the web works! :biggrin2:
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
JohnW
Post by JohnW » Fri Feb 25, 2005 10:28 am
yeah, I guess it did :lol:
DavidT
Post by DavidT » Sat Feb 26, 2005 2:12 pm
DaveP wrote:
DavidT wrote:My brakes were the same until the fluid was changed last week.
I also noticed the stopping force was reduced a little, no matter how hard I pressed. It stands on its nose again now :-)
Will never forget your brakes at LeMans matey!...Awesome stoppers.
Thanks Davey,
What a weekend that was, thanks again Eric if you are watching.
