Still on DRC (think a few bits have been replaced by last owner), gearbox was replaced about 5k miles ago.
Are there many RS6's out there that are at or beyond this mileage?
Why was that?mik15 wrote:147k on mine
- original engine,
- box replaced at 60k miles by Audi,
- 4th DRC set,
- 1 steering pump,
- 1 engine oil cooler,
- 1 alternator,
- 1 alternator harness
- 2 times VC gaskets
- 1 time both front axles
- 1 rear crank shaft seal
- 1 driver front door lock
- 1 fan and control unit
- 1 brake switch
- 1 EGT kit
- 1 fuel tank + pump
- 2 x timing belt kits(i know it should've been 4 of them but Audi always did it every 90k km, before the first 90k km they did replace the water pump and T-stat because they failed, however the belt was done for the first time at 90k km, in fact the last timing belt was done at 144k miles, so that means that the first timing belt lasted 85k miles, it didn't look cracked or as if it was to snap at all when removed, now i have used a Gates one, however i wouldn't go as far, it's pushing luck too much, but that is what Audi did...)
- plus lots of spark plugs, axle boots, miscellaneous seals, etc, etc....but those above would be the big players...and all has been done by Audi.
Users browsing this forum: Majestic-12 [Bot] and 105 guests
