Hi,
I have an intermittent problem with my 59 plate S4, sometimes the remote fob won't lock or unlock the car, strange thing is when this happens both keys don't work. I have a red blinking light on the fob so I know the battery is fine, I can unlock with the key in the door and then have no issues at all starting and driving the car.
I've tried replacing the battery and then immediately starting the car, leaving it running for a while, going for a 30 minute drive etc
Sometimes it works, sometimes it doesn't.
Audi want £60 to investigate, and then some more to fix no doubt.
Is there a sequence to reset the keys, everything I have read refers to a bladed key being put in the ignition and turned while holding various buttons, I can't do this with the fob type key.
Daz
Remote Locking Intermittent Problem (works / doesn't work)
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
- xxx_mojo_xxx
Re: Remote Locking Intermittent Problem (works / doesn't wor
Do you know someone with Vagcom who could run a quick diag through any faults/errors that might be logged?
Noxxx_mojo_xxx wrote:Do you know someone with VAGCOM who could run a quick diag through any faults/errors that might be logged?
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
- xxx_mojo_xxx
Where abouts are u based? Might be worth asking if someone on the forum who is nearby with Vagcom is happy to assist.
Are you absolutely positively 100% sure all doors are closed at the time? Reason i say is because I had an intermittent problem also when locking the car (advanced key) and it turned it out was because sometimes my daughter wouldn't close her door properly. Next time it happens, check all the doors.
Worth a shot anyway as everything else seems ok
Users browsing this forum: No registered users and 58 guests
