800 bhp b5 V8 4.7 turbo
Re: 800 bhp b5 V8 4.7 turbo
A few people commented on this tonight. Madness, slightly love the principle of it though.
BMW M2 Comp
RS4 Supercharged
Current Abarth 500c Two tone Grey and Mint - a modified go-cart.
Current T5 180 bi-turbo - modified, Reimo pop top, ABT kit, Caravelle 7 seats, going on 'air' this summer
Gone RS4 B7 Avant MRC, MK5 R32, 205 GTI, Mk1 golfs... plus some other poor souls
RS4 Supercharged
Looks like a Photoshop jobby
Zero feedback. Dodgy if you ask me
Feedback is not an issue as you would not buy without seeing and picking it up in person.
The point here is its appears to be an R8/RS4 engine with a 4.7 displacement and a turbo to boot.
- PetrolDave
I'd always understood that there wasn't sufficient spacing between the cylinders to bore out much above 4.2 certainly not to go as far as 4.7, so that leaves increasing the stroke...docurley wrote:The point here is its appears to be an R8/RS4 engine with a 4.7 displacement and a turbo to boot.
As for increasing the stroke to get extra capacity the piston velocities are already very high so it's likely that special pistons would be needed as well as the custom crankshaft. I suppose it would be possible but the cost would likely be astronomical and at £13,500 the seller would likely me making a significant loss.
Looking at the Dyno plot - rev limit at 6500 rpm so much lower piston speed. As such you could reduce the piston con rod length. This would increase displacement and also reduce compression ratio which you'd need to run those turbos.PetrolDave wrote:I'd always understood that there wasn't sufficient spacing between the cylinders to bore out much above 4.2 certainly not to go as far as 4.7, so that leaves increasing the stroke...docurley wrote:The point here is its appears to be an R8/RS4 engine with a 4.7 displacement and a turbo to boot.
I'm not convinced it's a fsi v8 though as I can't see any high pressure fuel pumps. It's probably just using the red rocker covers. The intake manifold is also from an s4 v8 I think.
They say it's a R8 lumpadsgreen wrote:I
- PetrolDave
Could it be an R8 block married to non-FSI B6/B7 S4 heads?docurley wrote:They say it's a R8 lump
That I don't knowPetrolDave wrote:Could it be an R8 block married to non-FSI B6/B7 S4 heads?docurley wrote:They say it's a R8 lump
That I don't know.PetrolDave wrote:Could it be an R8 block married to non-FSI B6/B7 S4 heads?docurley wrote:They say it's a R8 lump
- PetrolDave
Definitely not R8 or RS4 heads, the oil filler is in the wrong place and there's no high pressure injectors - so more likely to be 5-valve indirect injection heads.
Plus is that chains/belts on the front of the engine under the silver/white covers? Which would throw doubt on it being an R8 block.
Certainly looks like a hybrid engine of some sort to me.
Thats a C5 RS6 engine! The timing belts are at the front.... All V8 engines B7 on are chain driven and the chains are at the back of the engine.
Also it says its stroked not bored
that 0-125 vid was insane. Think it sailed past 60 in about 2.5/3 secs.
SOLD: B7 RS4 Saloon black optics
Dodge RAM 1500 Quad Cab 5.7 V8 - NOW GONE along with my shares in Shell
Previous: M3 CSL
Previous: M3 CSL
The C5 engine would rrequire the front to be extended so it can't be a C5.
Users browsing this forum: Google [Bot] and 381 guests
