Anyone know if the 20" r8 alloy wheel dimensions fit a b8 rs4 ?
Simon
R8 wheels on b8 rs4
Re: R8 wheels on b8 rs4
Hi,
Can't find data on the OEM R8 20" but I would assume that it has similar width dimensions & offset to the 19" so will use that to give feedback; someone else might chime in if I'm way off the mark.
It seems that the OEM R8 alloys are 19 x 8.5 ET42 front and 19 x 11 ET50 rear; standard B8 RS4 are 19 x 9 ET24.
Due to Quattro drive on RS4; should use same size alloy/tyre on front & rear axles:
You could use the 19 x 8.5 ET42 on front & rear axle with 18mm* spacer to achieve ET24 but existing 265/35 r19 tyre wouldn't work safely as the rim is too narrow. This wheel will also have quite a flat face with little to no concavity.
The 19 x 11 ET50 might work on rear axle (though probably not) with appropriate spacer size but I cannot envisage how it would work on the front axle without serious poke/rubbing issues. Again, existing 265/35 r19 tyre wouldn't work safely as the rim is too wide. On the flip side, this wheel should have reasonable concavity
Hope this helps
Hope this helps
B8 RS4 in Daytona Grey
A1 S line Black Edition (Mrs')
Recent Past:
BMW 325i M Sport Coupe (E92), BMW Alpina D3 (E90), A4 DTM Quattro (B7), BMW M3 (E46)
Recent Past:
No OEM 20" for the R8.
