Afternoon All,
I have an issue with my alarm, which goes off randomly, usually at night. I'm hoping someone has had a similar problem.
Car: 2010MY B8 S4 Avant (without keyless entry)
Problem: Alarm goes off randomly at night (3 times last night, hasn't done it for 6 weeks or so prior to this)
Containment: Unlock car with fob, lock again.
Info: All door locks work fine, no other issues with car. (data logs below)
My question is what is the root cause of the alarm going off, at the moment I have two thoughts:
- Door handle sensors (known fault)
- Vehicle energy management system (thinks 12v Battery is low, possibly reset current battery adaptions)
So, first a log from this morning:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 30 42 46 47 52 53 55 56 5F
62 72
VIN: WAUZZZ8K1AA126187 Mileage: 123910km/76994miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
30-Special Function II -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAKA) Labels: 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 HW: 8K0 907 551
Component: 3.0T SIMOS84 H06 0005
Revision: --------
Coding: 010C000C240F0128
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TFS8K0907551 A01007
ROD: EV_ECM30TFS8K0907551.rod
VCID: EED9625C3182496EF9B-80BB
No fault code found.
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K1 927 156 B HW: 0B5 927 156 E
Component: 0B5 30TFSIRdW H03 0003
Revision: --H03--- Serial number: 0000000395
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02043
ROD: EV_TCMDL501.rod
VCID: 346D30349F2EA3BE4FF-8061
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BC HW: 8K0 907 379 BC
Component: ESP8 quattro H04 0020
Revision: -------- Serial number: --------------
Coding: 290500
VCID: 7BFFDB08FAF0ACC6CE5-802E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 011200
VCID: 810329E0181C4616149-80D4
Subsystem 1 - Part No SW: 8T0 959 754 AG HW: 8T0 959 754 AG
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0171
Revision: D1000000 Serial number: 01260120100875
Coding: 66140000
VCID: 77F7C738C6D888A6AAD-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000448446
Coding: 260050914034AF010001000300001D0D0F1D470A00010141000000
VCID: 3C7D1814BF7E6BFE87F-8069
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 180110 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941003401763
Coding: 10010D
VCID: 489574C4FBA6375E137-801D
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD0BCMKO
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 418369E0D09C0616D49-8014
Crash sensor for side airbag; driver side:
Serial number: 6334MSME50010B550
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME4E426D52O
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME6C4D2D04V
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME6E4D3408U
Crash sensor for front airbag; driver side:
Serial number: 63732SME364E1A0C6
Crash sensor for front airbag; passenger side:
Serial number: 63832SME684E3C0EI
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JAR0007T
Coding: 000037
VCID: 3D7B1510A46462F6B01-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 P HW: 8K0 920 980 P
Component: KOMBIINSTR. H05 0255
Revision: 00200000 Serial number: CJ123MW1A
Coding: 2F07110002002600010000
VCID: 3F876F18AE6870E6A2D-806A
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E101180091
Coding: 00C303
VCID: 52A156AC0DFA8D8E7D3-8007
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 11
Reset counter: 57
Mileage: 122598 km
Time Indication: 0
Date: 2014.07.30
Time: 05:50:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 17
S4 Alarm Going Off
Re: S4 Alarm Going Off
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000013976
Coding: 01010101000000000000000102
VCID: 2D5B25507404F276001-8078
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009962160
Coding: 011C02204021410001
VCID: 458B7DF0CCB42A36E81-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0126104558
Coding: 013B062220390C000030023280000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882001151201
VCID: 7AF1DE0CF5CA95CED53-802F
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009948537
VCID: 448D60F4C78E133EFFF-8011
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000423999
Shop #: WSC 00000 000 00000
VCID: 346D3034972EA3BE4FF-8061
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: F7F7473886D808A62AD-80A2
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 J HW: 4F0 035 053
Component: Radio U Basic H45 0052
Revision: AB001007 Serial number: 341B-0A7699532
Coding: 010003010000000001
VCID: 244DC07427CE333EDFF-8071
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 F HW: 8T2 035 666 E
Component: H-BN-EU H47 0143
Revision: -------- Serial number: 475BV0A7544071
Coding: 01010101020681ED01000B1E000000030000
Shop #: WSC 00047 210 184061
VCID: 3E79121CA96279EEA9B-806B
Subsystem 1 - Part No: 8R0 060 884 J
Component: EUR 2010 1005
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102691423
Coding: 010C02204021210001
VCID: 428166ECDD9A1D0ECD3-8017
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102691442
End ---------------------------------------------------------------------
I then did some further digging on VAG-COM, and interrogated the convenience module:
After some digging on the internet I found the following, a TSB for A5/S5/A4/S4 regarding a similar issue- not my car does not have keyless entry.
The symptoms are all very similar, but my information isn't sufficient to know what the codes are in Module 46 > Block 18 (i.e. what does a value of 2.0 mean?)
- TSB suggests Value 2 (no communication)
- VW 'Tech-Tips' suggests Value 2 (Front Passenger Rotary Latch Switch)
So, where to go from here...?
My other question is regarding handed faults (i.e. passenger side) is Ross-Tech mature enough to understand implications RHD/LHD regarding fault handling. I.e. I'm using a VW America Tech Tip to decipher a European fault code, I presume fault code descriptions change with RHD/LHD?
Further information on supported codes my car has:
Module 05: Nothing Stored
Front Drivers Door: Nothing Stored
Front Passenger Door: Nothing Stored
Central Conv:
CAN 19:
Rear Left Door:
Rear Right Door:
Any help greatly appreciated!
Many Thanks,
Pete
Coding: 0000004
Central Conv:
CAN 19:
Rear Left Door:
Rear Right Door:
Many Thanks,
Pete
I'd get the hoover out and give the car a proper going over, every nook and crannie! Blasting up the M20 home from Le Mans I had a French spider drop down on a thread from the rear view mirror! Managed to find it when I got home. Dad had an issue a 10+ years back with a moth trapped in the car setting off the alarm
Ian- not a bad shout, but unfortunately still does it even with the interior monitoring turned off
Aye, that's what I thought! I did some more digging on VAG-COM and found battery health to be lower (38Ah from a 110Ah battery).
Replaced the 12v with the 'correct' one from halfrauds last night (65Ah) and VCDS shows 63Ah capacity and no problems with alarm last night or this morning.
Will see how this goes for the next few weeks, and then replace 12V with the correct one from Audi.
Pete
P.S- I asked TPS for a price on door sensors (common failure?) and was told these are only present on cars with keyless entry (so not an issue on mine)
Pete
Did you do any coding when you replaced the battery?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Nope, I was going to, but checked vag-com again with new battery, and seemingly it's learnt the attributes itself... Clever little bugger!
Users browsing this forum: No registered users and 46 guests
