Piggie Pipes (...what is this?????)
nikkak77
Post by nikkak77 » Thu Aug 14, 2014 6:03 pm
Guys,
While the car was in the workshop for teh clutch issue, I had asked them to keep on the stock cat back and remove the pre-cats.
The guys there once they removed the exhaust system, instead of coming across the standard "ceramic" materail, came across the below metallic stuff inside.
Since I am the 2nd owner of the car and due to that I cannot locate the previous owner who had claimed that the car was entirely stock, do you know what it is we are looking at?
TonyHayers
Re: Piggie Pipes (...what is this?????)
Post by TonyHayers » Thu Aug 14, 2014 9:30 pm
Um, that's just catalyst material. What was he expecting? ceramic floor tiles? :)
06 Phantom Black Saloon:
^ GONE :cry:
rwilsonrs4
Post by rwilsonrs4 » Thu Aug 14, 2014 9:38 pm
yeah thats the std OEM precats whch are the same as the ones further down but closer to the manifold so heat up faster to reduce emissions earlier ,
1/4 mile 12.01 secs 123.5mph
nikkak77
Post by nikkak77 » Thu Aug 14, 2014 9:53 pm
Just noticed that i failed to describe it correctly.
Instead of finding inside after the mesh on the pics the honeycomb material, we found sth like a metallic precat.
Have you ever seen sth like that?
bhprs4
Post by bhprs4 » Thu Aug 14, 2014 10:01 pm
The RS4 uses a metal cat in the pre cat. So you won't find the normal ceramic honey comb material.
To remove I used a drill to help break it up and then pulled out in bits.
09 C6 RS6 Black Saloon-stg 2 ECU and Gearbox map, secondary cat deletes, ITG filters, AP 390 brake discs.
nikkak77
Post by nikkak77 » Fri Aug 15, 2014 8:47 am
bhprs4 wrote:The RS4 uses a metal cat in the pre cat. So you won't find the normal ceramic honey comb material.
Thanks for the tip. Had no idea. :bash:
It is now off...
sakimano
Post by sakimano » Fri Aug 15, 2014 1:35 pm
They're basically metallic race cats. Unlike almost any other audi I've seen before
nikkak77
Post by nikkak77 » Sun Aug 17, 2014 3:27 pm
I always thought - by mistake obviously - they had the honeycomb material.
I removed them and the strange thing is that i have not a CEL light.
I have driven it for a couple of days now in mostly small distances but no light at all.
I have neither added spacers on the O2 sensors nor moved them further apart.
Shouldn't have produced the warning light?
sakimano
Post by sakimano » Sun Aug 17, 2014 6:37 pm
It will come don't worry. Can take 100 miles.
You probably already have fault codes... Maybe have a look?
nikkak77
Post by nikkak77 » Sun Aug 17, 2014 6:41 pm
No fault codes in VCDS....
voidopolis
Post by voidopolis » Fri Sep 26, 2014 6:30 pm
nikkak77 wrote:No fault codes in VCDS....
did you end up ever throwing a code or have any problems?
nikkak77
Post by nikkak77 » Fri Sep 26, 2014 8:00 pm
Yes, but fixed it via a tune
Users browsing this forum: Bing [Bot] and 298 guests
