Original Cross Drilled Brakes Audi
2.7 V6 30v biturbo - 380 bhp
zeke
Post by zeke » Sat Jan 29, 2005 1:02 am
Do anybody know the part number in the optional cross drilled brakes from audi? :?:
Zeke
simple1
RE: Original Cross Drilled Brakes Audi
Post by simple1 » Sat Jan 29, 2005 8:19 am
They were not optional as such, they are Quattro GMBH
YTH Perforated brake discs, 1100.00
front/rear wheels
YTI Perforated brake discs, front wheels 580.00
YTJ Perforated brake discs, rear wheels 520.00
zeke
Post by zeke » Fri Feb 18, 2005 9:18 pm
Ok, so I can just go to any AUDI Distributor and just ask for:
Zeke
simple1
Post by simple1 » Fri Feb 18, 2005 10:08 pm
You need to inform them that they are Quattro GMBH parts and normal Audi parts, most dealers will only understand VAG part numbers
johneroberts
Post by johneroberts » Sat Feb 19, 2005 10:41 am
Zeke
best bet is to buy them from a retailer in Germany
Audi Zentrum
Am Main
Frankfurt
Herr Wintermeier
they know about them
jr
Driving is believing
RS246 Founder
kiwi_mtm
Re: Original Cross Drilled Brakes Audi
Post by kiwi_mtm » Sat Feb 19, 2005 8:46 pm
zeke wrote:Do anybody know the part number in the optional cross drilled brakes from audi? :?:
Zeke
can you run them with std pads ?
RS4ever
Post by RS4ever » Sun Feb 20, 2005 1:41 pm
kiwi_mtm wrote: can you run them with std pads ?
Yes, no problem. They will wear out quicker because they keep getting a layer skimmed off them, but your disks will last longer. You must certainly NOT use the Pagid yellows that are supplied with them.
I use, on JR's recommendation, pagid orange fronts and blue rears.
DavidU
RE: Re: Original Cross Drilled Brakes Audi
Post by DavidU » Sat Feb 26, 2005 10:01 pm
Hello their i have the X drilled numbers as i have been putting them on RS4"S with RS6 calipers and pads.The result is a very hard peddal and no brake fade its worked on the vehicles i have modded havent had any problems
DavidU.
bjacks
Post by bjacks » Sat Feb 26, 2005 10:24 pm
Where have you been sourcing the parts David?
Ben
zeke
Post by zeke » Sun Jul 24, 2005 12:16 am
So, David?
K2
Post by K2 » Sun Jul 24, 2005 8:21 am
I am just going through with front brake upgrade, using RS6 cross drilled discs for my RS4, which are strangely about the same price as RS4 standard solid discs!
They can be bought off the shelf from an Audi dealer as they are an option for the RS6, and fitted to the 6+ as standard kit.
They are being fitted with Brembo 6 pot GT3 callipers.
I will post a more detailed description following the work, regarding any alterations that may be neded to make the rotors fit the RS4. When I was looking for the drilled GMBH RS4 discs, I had resolved that going direct to GMBH was probably the most direct solution, following advice from VAG parts.
TWH
Post by TWH » Sun Jul 24, 2005 12:54 pm
From what I've heard, GmbH are an impossible company to contact/deal with, thius is why Audi IK won't get the GmbH discs in. Unfortunately the guy at AMD lost his supplier for GmbH about a month ago and is trying to find a new one at the moment. If anyone else has managed to find a supplier please do tell as I need to put on a new set of rear discs and wanted to go the GmbH route!
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten :(
TarmacTerrorist
Post by TarmacTerrorist » Sun Jul 24, 2005 1:24 pm
JR psoted a contact further up this thread, Mr Herr Wintermieir (sp), phone international directory for there number :thumb:
Too much is bad.
Plenty is better.
johneroberts
Post by johneroberts » Sun Jul 24, 2005 5:13 pm
TWH wrote:From what I've heard, GmbH are an impossible company to contact/deal with, thius is why Audi IK won't get the GmbH discs in. Unfortunately the guy at AMD lost his supplier for GmbH about a month ago and is trying to find a new one at the moment. If anyone else has managed to find a supplier please do tell as I need to put on a new set of rear discs and wanted to go the GmbH route!
Thats because Bushy and my self were actually sourcing them from Zentrum Audi in Frankfurt vis Herr Wintermeier, i cant remember how many times i have posted this number up..use the serach facility
jr
RS246 Founder
Users browsing this forum: No registered users and 105 guests
