3,000 to 8,000 3rd gear test,
scaghead
Re: 3,000 to 8,000 3rd gear test,
Post by scaghead » Sun Jun 15, 2014 9:36 pm
Bit of a sloppy start..lol..but that looked fast enough..try the third gear test fella..
ashy
Post by ashy » Sun Jun 15, 2014 9:38 pm
scaghead wrote:Bit of a sloppy start..lol..but that looked fast enough..try the third gear test fella..
Yeh was a pants start....lol
Do you roll on from say 2k and start timing at 3k or hold it at 3k then floor it and start timing?
wrekka
Post by wrekka » Sun Jun 15, 2014 10:47 pm
Put in 3rd gear at very low revs (but dont stall) floor it at 2k- when you hit 3k (or just before due to reaction time) hit the timer then stop it at 8k
TTS RS4 -amazing machine,
Previous:
ashy
Post by ashy » Sun Jun 15, 2014 11:54 pm
wrekka wrote:Put in 3rd gear at very low revs (but dont stall) floor it at 2k- when you hit 3k (or just before due to reaction time) hit the timer then stop it at 8k
Got it, will have a try next chance i get :thumbs:
ashy
Post by ashy » Sat Jul 05, 2014 6:08 pm
Got round to having a go at this:
http://youtu.be/4Q6_jQcoAL8
seams around the 8.5 so should be around right you think?
kernowrs4
Post by kernowrs4 » Thu Jul 10, 2014 12:34 am
Did mine before i went away, flat section of road cloudy day aroun 16 degrees and i did 8 runs and had a average of 8.6 so happy with this :-)
coldo
Post by coldo » Sun Jul 20, 2014 7:17 pm
After reading a thread in this section of the forum, I felt the need to go out and do this test on my own car!
Just for reference, here are my results and conditions;
Car: Stock B7 RS4, Sport button pressed and ESP off.
Mileage: 67k with no evidence of carbon clean ever having been done.
Fuel: 1/2 tank of 99RON pump fuel
Driver: 121kg
Temp on gauge: 20 degrees Celsius
Height above sea level: 8m
Recorded on cars own lap timer.
Time 1: 8.8s
Time 2: 8.4s
Time 3. 8.9s
Time 4: 8.4s
Time 5: 8.3s
Average time: 8.56s - Even if i was a bit sharp with timer, it still keeps it within the 'acceptable' times so all in i'm pretty happy with that.
B7 RS4 Saloon - Sprint Blue
stu
Post by stu » Fri Aug 01, 2014 1:33 am
My 8.5 seconds in November 2012 is now high nines and touching ten.
The car doesn't seem to rev as freely/wildly and it's most noticeable after the 5.5k surge which is still present. Very occassionally when doing the runs there is a subtle blip in progression through the revs - somewhere above 6k. Having read earlier threads on vacuum leaks and flaps I'm none the wiser as to the cause.
My car is standard but with a K&N filter (provided Audi didn't swap it out when it was serviced last week). It got a new clutch and new fluids all round last week. None of this is to blame though - I noticed the rev blip a few months back, hoped (naively) that it was the clutch :bash: :)
Any ideas what I should do?
coffey555
Post by coffey555 » Fri Aug 01, 2014 10:05 am
Stop taking it to Audi and find a decent local indie that knows what they are doing. It will also be cheaper plus your air filter will be safe!
Sounds like a classic vacuum leak but without a VCDS cable to log error codes and perform function tests it is hard to be sure.
Misano Red RS4 B7 Avant
sakimano
Post by sakimano » Fri Aug 01, 2014 12:05 pm
Yes I would guess either vac leak, or it is 45 C and high altitude where you are currently testing
stu
Post by stu » Fri Aug 01, 2014 2:08 pm
coffey555 wrote:Stop taking it to Audi and find a decent local indie that knows what they are doing. It will also be cheaper plus your air filter will be safe!
It's a hard habit to break :D
The service I get at Tyneside Audi is superb. But you're right, and with Glenn and Revolution down the road from me it's silly not to, particularly for stuff like this.
sakimano wrote:Yes I would guess either vac leak, or it is 45 C and high altitude where you are currently testing
:bash: Good point: yes, same place (virtually sea level), same time of day, just different season. It was only 6 degrees hotter.
I'll chat to Revolution. I'm getting a VCDS today to play with too while I'm on my Ireland road trip. Cheers fellas :beerchug:
sakimano
Post by sakimano » Fri Aug 01, 2014 2:09 pm
6 degrees is very little. Maybe 1.5%.
Something else is definitely wrong.
stu
Post by stu » Fri Aug 01, 2014 2:15 pm
sakimano wrote:6 degrees is very little. Maybe 1.5%.
Thanks again for you input. Fingers crossed I'll get the extra power back before Spa in September.
hlbeckley
Post by hlbeckley » Wed Aug 06, 2014 7:06 pm
8.6 for altitude I think is decent
Fresh carbon clean yesterday
Intake separators removed
K&N filter
Custom decat down pipes and X pipe
KGRS4
Post by KGRS4 » Wed Aug 13, 2014 7:33 pm
I did this the other day and got average 8.2sec which I think im happy about :) it had a decoke before I bought it 7 months ago and I only carried out this test last week :)
Red B7 RS4 Saloon......That is all!!
Users browsing this forum: No registered users and 100 guests
