Photos of my RS4 B8 on H&R Springs/Spacers
4.2 V8 32v FSI - 444 bhp
'Qfizzle
Re: Photos of my RS4 B8 on H&R Springs/Spacers
Post by 'Qfizzle » Wed Jul 30, 2014 12:09 am
TechNick wrote:Is technically a modification, so usual rules would apply with warranty/insurance
The dealer will make you sign a paper stating that if anything goes wrong with the suspension is not going to be covered.
'14 RS4 Avant Exclusive || '17 BMW M2 6SPD || '16 Maserati Ghibli
matthew.lewis2
Post by matthew.lewis2 » Wed Jul 30, 2014 8:03 am
'Qfizzle wrote:
matthew.lewis2 wrote:Looks stunning.
Few questions if I may...
Could you let me know the part numbers of the spacers?
I'm thinking of going with the MTM adjustable springs so that I could dial out any rubbing issues. How much higher do you think you would need to raise yours (if you could) to stop the rubbing?
Thanks mate.
Part number is
24MM: B2455668
30MM: B3055668
It doesnt need to be raised at this level, it needs to go to the alignment shop for a bit of negative camber. I am not sure if the adjustable springs from MTM are made for the DRC option, so you better check if they are.
Thanks for the part numbers, did you get new wheel bolts? If so, can you let me know what you ordered?
The MTM spring kit is offered in DRC and non-DRC models. I would be worried about uneven tyre wear if negative camber was added, so would probably just accept the ride height being slightly higher than your stunning setup.
Where is it rubbing?
UAE CARS
2009 Toyota Landcruiser - White -4.7 V8 VXR (SOLD)
2014 Mercedes ML500 - 4.7 V8 Twin Turbo (SOLD)
2008 Audi RS4 - Sprint Blue (SOLD)
2002 Range Rover 4.6 V8 HSE (SOLD)
2007 Golf R32 - Black (SOLD)
2005 Lincoln Navigator - White (SOLD)
UK Cars
2015 Landrover Defender 110 Heritage (SOLD)
2014 Audi RS4 - Sepang Blue (STOLEN)
2003 EP3 Civic Type R - K-Pro Remapped (SOLD)
2004 Golf GT TDi 140 - Superchipped to 189bhp (SOLD)
2003 Audi A2 1.4 Tdi
matthew.lewis2
Post by matthew.lewis2 » Wed Jul 30, 2014 8:06 am
TechNick wrote:
SWRS4 wrote:That looks great, didn't think the RS4 could handle such big spacers. I was think about going 10mm front and 15 mm rear, thinking that was a bit adventurous!!
Could be wrong, but I suspect he's talking total widening across the axles, whereas you're talking per hub... in which case they're both in the same ballpark (this one being slightly wider at the front only)! :thumbs:
Confirmed, the part numbers quoted relate to 12mm and 15mm spacers.
UAE CARS
UK Cars
blueaudi
Post by blueaudi » Wed Jul 30, 2014 10:28 am
I had 5mm spacers on my 991 as a manufacturer option, the difference was subtle but that was all I wanted. Would similar on an RS raise any issues at all, I'm assuming that 5mm is neither here nor there in terms of bearings and steering etc?
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
jpcartel
Post by jpcartel » Wed Jul 30, 2014 10:33 am
blueaudi wrote:I had 5mm spacers on my 991 as a manufacturer option, the difference was subtle but that was all I wanted. Would similar on an RS raise any issues at all, I'm assuming that 5mm is neither here nor there in terms of bearings and steering etc?
My Brabus CLS came with 25mm spacers all round from the factory and MB never made any comment about it. I suppose some companies use them and other don't so they could decide to make it an issue if they wanted to..
2011 RS5 - Daytona Grey
Sports Pack, Sports Exhaust, B+O, Nappa, Black Optics, Tech Hi, Home jobby (garage door thingy) and whatever else its got..
RS6chris!
Post by RS6chris! » Wed Jul 30, 2014 8:30 pm
Awesome stance.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
'Qfizzle
Post by 'Qfizzle » Thu Jul 31, 2014 1:10 pm
Thanks mate.
Part number is
24MM: B2455668
30MM: B3055668
Yes, you have to buy the bolts separately, i got them from H&R as well.
Its rubbing in the front only, inner wheel wells. The only way to fix this issue is to go negative camber if you're not going with the coilover setup. I wanted a adjustable setup, but with that i will loose the functionality of the DRC.
D8vil
Post by D8vil » Fri Aug 08, 2014 8:18 pm
Hi
i have the dredded slight knocking noise that Audi cannott fix and i am thinking this is the best suspiesnion option plus i guess no DRC.
Am i correct ?
I love the car but the knocking is a piss take on a high end car.
BMW2RS4
Post by BMW2RS4 » Fri Aug 08, 2014 9:59 pm
D8vil wrote:Hi
Am i correct ?
H&R produce an excellent system but it isn't necessarily the only/best option; the KW coilover spring kit works with DRC and is also height adjustable.
http://www.demon-tweeks.co.uk/performan ... ear-5-20mm
I have the KW system fitted and, though mine is a more conservative drop than the OP's, I could achieve the same ride height if desired; there is the added benefit that I can return the car to within 5mm of stock height if required.
On the issue of rubbing, I would be interested to know if, with 15mm spacers at rear, there is any rubbing with full load; i.e, 5 adult passengers and a couple of hundred kilos in the baggage area. Little bit like the following :D
http://www.autogespot.co.uk/audi-rs4-av ... 06/10#img9
B8 RS4 in Daytona Grey
A1 S line Black Edition (Mrs')
Recent Past:
BMW 325i M Sport Coupe (E92), BMW Alpina D3 (E90), A4 DTM Quattro (B7), BMW M3 (E46)
'Qfizzle
Post by 'Qfizzle » Tue Aug 12, 2014 12:33 am
There are two screws in the inner fender line that the front tires are rubbing on when rebounding. But, i took them off, it does not rub anymore. The inner well has many screws inside, but this is the only screw that is sticking out. Ive went on high speeds numerous times, and the inner fender well plastic is still holding well and i doubt it will ever come off. Its solid.
Rear tires do not rub. I have tried 3 passengers with me, on full load throttle.
I am interested in the KW sleeve kit like the one you have. How rough is the ride now on Dynamic? With the H&R's, its the same stiffness but the rebound is softer than OEM. If the KW is stiffer than the OEM on Dynamic, i will go for it.
BMW2RS4
Post by BMW2RS4 » Tue Aug 12, 2014 8:16 am
Thanks for the information regarding rubbing. I'm looking into buying aftermarket rims; probably a square set up with 20" x 10" ET25 retaining the standard 265/30 r20 tyres. With a 12mm spacer upfront & 15mm rear, yours is a more aggressive setup than my proposed one so I'm pleased that there aren't rubbing issues. Btw, are you looking to go with aftermarket rims in the future?
It's interesting that the H&R springs are the same stiffness as OEM as they have a reputation for being quite stiff; usually Eibach produce the softer spring which is closer to OEM. The KW spring comfort has improved with mileage though that might be due to me getting used to the stiffer ride! It is slightly stiffer than OEM and this is reflected in the rebound; now the car feels much more planted than it did. BTW, I have been told that KW also produce the one offered by MTM but you will pay a premium for the MTM version.
Recent Past:
'Qfizzle
Post by 'Qfizzle » Fri Aug 29, 2014 3:42 am
'Qfizzle
GordonBoy
Post by GordonBoy » Thu Oct 08, 2015 5:43 pm
Hi Qfizzle,
I am trying to use 24mm front and 30mm back spacer, same as ur config but with KW coilover spring setup. Can u give me the part no. for the bolts? I cannot source the bolts.
Thanks!
Padd0011
Post by Padd0011 » Mon Jun 10, 2019 9:59 am
Hi all, I’m new to the forum and am looking to lower my b8 rs4, love the stance of this one and was wondering what drop the springs were as I keep finding 2 variations, a 15mm drop or a 30mm drop
Users browsing this forum: No registered users and 256 guests
