Anyone running a current group buy on front brake discs B7
My 2006 B7 needs from discs anyone running a group buy at the moment??
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
Re: Anyone running a current group buy on front brake discs
Have you considered getting a set of Phaetons and swapping over your current B7 bells.
Best price is normally when eurocarparts have a 30% discount code.
Try circuit supplies. AP Racing not OEM.
I'm looking at Tarox front discs for £669 per set at the mo just trying to save myself a bit cash!!tanoga wrote:Have you considered getting a set of Phaetons and swapping over your current B7 bells.
You can get a set of Phaetons for less then £380 from VWWilkinsonRS4 wrote:I'm looking at Tarox front discs for £669 per set at the mo just trying to save myself a bit cash!!tanoga wrote:Have you considered getting a set of Phaetons and swapping over your current B7 bells.
tanoga wrote:You can get a set of Phaetons for less then £380 from VWWilkinsonRS4 wrote:I'm looking at Tarox front discs for £669 per set at the mo just trying to save myself a bit cash!!tanoga wrote:Have you considered getting a set of Phaetons and swapping over your current B7 bells.
Mmm you got a weblink for these Phaetons?? And what are they and are they any good!?
I've got a Brembo Brake Kit fitted so will they be fine with that set up??
The front brake discs on the Audi B7 RS4 are the same as the front brake discs on the VW Phaeton EXECPT the VW Phaeton discs are NOT crossed drilled and the bells on the Phaeton discs are different to the Audi B7 RS4 bells. As you already have a set (I'm assuming you have a set on the B7 at the moment?) of Audi B7 RS4 discs you can take the bells off these and fit them to a set of VW Phaeton discs. The Phaeton disc part number is 3D0615301N. I have these discs on my Audi B5 RS4 which replaced a set of B7 RS4 discs that were on the car previously. I'm well please with themWilkinsonRS4 wrote: Mmm you got a weblink for these Phaetons?? And what are they and are they any good!?
I fancy a set of alcon discs inquired recently with one of their distributors (performancebraking,com) they are direct replacement for oem but better and considerably lighter they are used on alot porsches and gtr's.
As discussed the discs are a minimum order quantity of 3 pairs. Prices are £325.40 + del + vat for plain finish and £360.54 + del + vat for s grooved. They weigh approximately 8 kg each and are 365 / 241 x 34mm.
just two other people
Daytona Avant - Optics - Titanium pack - MRC 464.6ps 513Nm - H&R ARBs + Springs - Apikol Diff mount - 034 Tranny mount - JHM Shifter
I'm being naive here but are they as good and easy to fit as the old discsthedoluk wrote:I fancy a set of alcon discs inquired recently with one of their distributors (performancebraking,com) they are direct replacement for oem but better and considerably lighter they are used on alot porsches and gtr's.
they are direct replacement for oem but lighter and better. oem discs are 12kg+ these are 8 kg and look the nuts.
Mmmm interesting, you got any pictures mate?thedoluk wrote:they are direct replacement for oem but lighter and better. oem discs are 12kg+ these are 8 kg and look the nuts.
I was gonna go with the Tarox disc with Yellow Stuff Pads but discs are £669 per set
Weight saving aside, spend another £140 and you can get the OEM ones.thedoluk wrote:I fancy a set of alcon discs inquired recently with one of their distributors (performancebraking,com) they are direct replacement for oem but better and considerably lighter they are used on alot porsches and gtr's.
I agree Mike, rang them about these and they said they are great for track days and racing etc but will wear quickly do tgèy don't advise people to fit them for general road use as they won't last as long as OEM onesMikeFish wrote:Weight saving aside, spend another £140 and you can get the OEM ones.thedoluk wrote:I fancy a set of alcon discs inquired recently with one of their distributors (performancebraking,com) they are direct replacement for oem but better and considerably lighter they are used on alot porsches and gtr's.
There's a photo of a B7 with Alcon discs in this thread:
http://forum.rs246.com/viewtopic.php?f=35&t=108037
Users browsing this forum: No registered users and 89 guests
