Hesitation
mavada
Hesitation
Post by mavada » Wed Jul 02, 2014 3:21 pm
Hi all,
Went for a spin today and noticed a whining sound and occasionally ticking sound coming from around the rear wheel area, not constant, but for little periods.
Sometimes suddenly louder.
Noticed also on full throttle a huge hesitation, couldnt get more than 3000 rpm, gearchanges are smooth, but couldnt reach kickdown.
Didnt had a Phone with me to record the sound.
Looks like fuelpump?, cos of the area the whining is coming from, and the hesitation?
Dont know the above is typical for fuelpump faillure...?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
SuprSi
Re: Hesitation
Post by SuprSi » Wed Jul 02, 2014 3:52 pm
Ah, not good. Could be the bearings or brushes in the fuel pump given up. The symptoms make sense.
I think mines on the way out because it occasionally makes quite a loud noise when you first turn the ignition on in the morning for like half a second then settles down. Probably waiting for the most inconvenient time to fail!
Nobby
Re: Hesitation
Post by Nobby » Wed Jul 02, 2014 3:59 pm
How old is the fuel filter?
Daytona RS6 Avant
mavada
Re: Hesitation
Post by mavada » Wed Jul 02, 2014 4:01 pm
yeah thought about that to, probably check that first, think its the Original one....
Yellow Koni's
mavada
Re: Hesitation
Post by mavada » Wed Jul 02, 2014 4:14 pm
...ive got a drawing of the fuelpump/filter, but dont know where its located...
Yellow Koni's
amanda1
Re: Hesitation
Post by amanda1 » Wed Jul 02, 2014 4:41 pm
Mines is on drivers side approx between drivers and passengers door under a cover..........remember I have the correct side for the steering wheel unlike you foreign lot :assflash:
950 nm torque!
Nobby
Re: Hesitation
Post by Nobby » Wed Jul 02, 2014 5:09 pm
As Amanda says. Annoyingly they don't have the nice connectors which just pop off, but have jubilee style clips.
Daytona RS6 Avant
mavada
Re: Hesitation
Post by mavada » Wed Jul 02, 2014 6:06 pm
aha, so the carpet has to come off?
it was a brutal hesitation, thought the box went toast...
Yellow Koni's
amanda1
Re: Hesitation
Post by amanda1 » Wed Jul 02, 2014 6:11 pm
mavada wrote:aha, so the carpet has to come off?
No the fuel filter is on the outside of the car on the floor plan ie underneath the drivers and passengers side doors.
950 nm torque!
mavada
Re: Hesitation
Post by mavada » Wed Jul 02, 2014 6:41 pm
Thanks all, will have a look :thumbs:
Yellow Koni's
saulcupra
Re: Hesitation
Post by saulcupra » Thu Jul 03, 2014 10:02 am
4B0 906 089A Fuel Pump £199.45
6N0 201 511A Fuel Filter £7.34
rossi46
Re: Hesitation
Post by rossi46 » Thu Jul 03, 2014 11:43 am
Reference fuel pumps, is it always the case people replace with an OE part?
I seem to recall Bosch 044 pumps mentioned on modified/performance cars ( not specifically C5 RS6's ) - Wondered if this would be a recommended upgrade should the original part fail ??
amanda1
Re: Hesitation
Post by amanda1 » Thu Jul 03, 2014 12:03 pm
I have a loba fuel pump on mine ;)
950 nm torque!
SuprSi
Re: Hesitation
Post by SuprSi » Thu Jul 03, 2014 12:11 pm
Good call on the Bosch 044 pump. Loba sell a few different models of the bosch pumps. The 044 is good for 650hp while maintaining 5 bar by the look of it. Would be interesting to see what the spec of the audi pump is.
Loba have added the special Loba RS6 tax though by the looks of it! :shock: Ebay!
rossi46
Re: Hesitation
Post by rossi46 » Thu Jul 03, 2014 1:47 pm
I don't fully understand if the 044 is additional or standalone pump? Does it require the OE pump to run it? Just wondering if it maintains its own pressure, or if the OE one works with it ( and therefore needs to be functioning @100% to validate the 044).
In addition, if a car has been mapped with the std. fuel pump, will a tweak be needed if a greater level of fuel is being supplied via a modified pump ?
Users browsing this forum: srichards and 86 guests
