My first thought was a better/higher fence all right!KGRS4 wrote:I've just had a thought, I could clad my side of the fence to stop the fumes going through!
I'd say if you made some effort to rectify it she should be happy.
matthew.lewis2 wrote:Noting that your are in Scotland, but here is a thought...
in England, the Highway Code/law states that vehicles shouldn't reverse from a minor to a major highway. https://www.gov.uk/using-the-road-159-t ... 200-to-203
So many Britons 'break the law' each day unknowingly by reversing out of their drive onto a highway (a minor to major reversing manoeuvre).
On the assumption that you are currently reversing from the road to the final parking place then you are doing your best to comply with the highway code and be a good citizen!
I normally wait for the revs to drop from 1500 to under 1000 then I drive off it's only 20secs worth just gives everything that little bit head start before you put load on it that's just how I am with fast idles/warm ups on start ups even on the trucks I served my time on. Since being told that when an apprentice I've always just let it run it's course for the little time it takes. But to stop my neighbour moaning looks like I might just have to start driving off.rwilsonrs4 wrote:tho i agree its none of her business , in fairness it its better to start the car up and immediately drive off without being hard on it , the engine will heat up much faster as it has work to do , the oil gets up to temp quicker , its a myth nowadays to let the car warm up on its own , those were the old days when it was mono grade oils, that needed to be warmed up a bit to function properly ,when there were carbs with chokes that were very rich running so didnt drive worth a <beep> till things warmed up . ok if its frozen over or something thats different , you have to clean it off , but better to drive off right away and drive normally until its up to temp then rag it all you want
ha haUsers browsing this forum: No registered users and 373 guests
