Noticed that mine is making that noise in the morning on full lock. What was the fix? Might get my indie to have a look next week at her service.DaytonaRs4 wrote:I believe it was a little releif valve tgat was removed from the system. Still a slight whine but no where near as bad
massive power loss :(
Re: massive power loss :(
- DaytonaRs4
to be honest im not sure its a fix, little whine still there, i believe most of our cars do this after ageing, i was told just to ensure that fluid is topped up (p/s fluid replaced also last month) and it should be ok for now but if noise increases then poss new pump required.
it is just annoying really when parking car, not the kinda noise i like my car giving out so i just try to avoid full lock
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
you should never hold any car with power steering on full lock
yeah, onloy a whine first thing when getting out of the carpark, other than that its all good, cheers!
The guys drained the fluid as it looked a little milky and also noted it needed to be topped up.
Since then not a whine!
- MartayMcFly
- 5th Gear
I've just emailed Autohaus re a decoke and map. I also see they do APR supercharging... shame it's almost £20k all in.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
- DaytonaRs4
MartayMcFly wrote:I've just emailed Autohaus re a decoke and map. I also see they do APR supercharging... shame it's almost £20k all in.
Good stuff. Davy at autohaus looked after me. I was £600 for carbon clean and further £150 for deflap.
I looked into APR map but decided against it to wait for custom map. Im sure surfpunkman on here has the APR map. Give him a shout see what he thinks..
Ecotune glasgow also do apr but with the added benefit of before /after dyno which autohaus dont have....
Im sure APR have 20% sale on just now too.
Hey!!! You make that sound like a bad thing!!! LolRick_RS4 wrote:im not trying to sound like Arthur here but 100+ bhp from carbon buildup?...
I got feelings too!!
A picture of the sled for good measure
Guys may I ask whether you had any fault codes in either VCDS or anywhere else when there was a vac leak issue?
I had asked a local dealer to do a check while trying to fix my clutch and came back saying that there is no need as this system is so sensitive that it would have produced fault codes.
I a, asking cause before the decoke my dyno on a maha 3000 was a mere 340 on crank. Haven't been able to dyno after the carbon clean due to the clutch problem.
Guys I'm new on here and have had RS4 for couple months
Just read this convo
Had Dyno done and hitting 360bhp
Planning on taking it to Autohaus in Edinburgh for carbon clean and deflap and David there has mentioned apr stage 1 map
Daytona Rs how did you find car after clean up and did u get final results on rolling road from Eco tune?
A for audi suggest that walnut method so not sure who to go with
- PetrolDave
Take the drive "darn Sarf" to MRC and have them do a carbon clean and a Stage 2 remap - it's well work the time, miles and petrol as you'll smile so much more!AQ RS4 wrote:Planning on taking it to Autohaus in Edinburgh for carbon clean and deflap and David there has mentioned apr stage 1 map
bluenosewrx
Both will be good, I've used a for audi in past, replaced oil cooler and pipes and aux rad, brilliant serviceAQ RS4 wrote:Guys I'm new on here and have had RS4 for couple months
+1PetrolDave wrote:Take the drive "darn Sarf" to MRC and have them do a carbon clean and a Stage 2 remap - it's well work the time, miles and petrol as you'll smile so much more!AQ RS4 wrote:Planning on taking it to Autohaus in Edinburgh for carbon clean and deflap and David there has mentioned apr stage 1 map
akoblivius
Hi.
Can you ask me please which products they use for the carbon cleaning?
I'm from Hungary and there are just very few rs4.
Thanks your help.
I didn't felt now any power loss,but maybe better to do a carefully cleaning between 60-70k miles?
thx
Thanks your help.
thx
akoblivius
Hi.
Thanks your help.
thx
Thanks your help.
thx
Users browsing this forum: Zyox and 372 guests
