Anyone know if the 174mph upgrade can be retrofitted to the rs4? I'd rather do that then have some company delimit it and lose my warranty.
I'd be surprised if that were true - the B7 RS4 (with "only" 420PS) has been GPS measured by quite a few owners on German autobahns at 168mph or more - when fitted with the standard "155mph" limiter...doodlebug wrote:I agree with HYFR, i'd not bother, won't get much passed 155, 174 is optimistic.
This!! Mines got the limiter lifted, but I didn't spec it, waste of money' as it will go over the stated 155 standard, as did my b7IMHO, the £1500 they want to up the limit is a massive rip off
I would concur. My spec mentions nothing of removal of the 155 limit, but I have also managed at run of circa 165+ in mine under similar conditions to Graeme mentions (all be it I didn't have a GPS device running at the time), although my mileage was a higher than 1200. I don't see the point / need to remove it unless you own a strip of tarmac the length of the M275....?Graeme4130 wrote:At Vmax last June, mine did repeated runs to an indicated 169, which gps registered at 163
Admittedly, the car was only 1200miles old, but it genuinely didn't have much left to give, and as Dave said, you'd need a blimmin long straight and a tailwind to hit 174
It did loosen up as the mikes went up, but still not by a massive amount and my car was making the full 450ps at the 246 RR Day
More weightPetrolDave wrote:I'd be surprised if that were true - the B7 RS4 (with "only" 420PS) has been GPS measured by quite a few owners on German autobahns at 168mph or more - when fitted with the standard "155mph" limiter...doodlebug wrote:I agree with HYFR, i'd not bother, won't get much passed 155, 174 is optimistic.
So surely the B8 with 30PS more and a slipperier shape should be able to beat that?
Weight has a tiny tiny almost negligible effect on top speed.HYFR wrote:More weightPetrolDave wrote:I'd be surprised if that were true - the B7 RS4 (with "only" 420PS) has been GPS measured by quite a few owners on German autobahns at 168mph or more - when fitted with the standard "155mph" limiter...doodlebug wrote:I agree with HYFR, i'd not bother, won't get much passed 155, 174 is optimistic.
My RS 5 had the factory derestriction and would struggle to hit 170
