Hi folks
I can't find anywhere that sells 2nd decat pipes? Looking for a set that could bolt on so the car could be put back to stock if need be?
Smokey
Second decat pipes?
Re: Second decat pipes?
The 2nd cats are welded to the downpipe. So no bolt on options, unless you buy the whole downpipes, modified......
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
360 Modena (manual)
F430 Spider (F1)
You have three options and all requires cutting off the OEM cats.
1: Buy cat replacement pipes like Supersprint and use pipe reducers to fit to your OEM cat back exhaust.
2: Replace OEM cats with 100 or 200 cells race cats.
3: Have custom replacement pipes made to fit the OEM cat back exhaust.
You will still pass the MOT with all three options.
What are you trying to achieve? If it's just a bit more noise then try taking out the front silencers on OEM exhaust with straight pipes just gives a little more noise. I'm more than happy with results.
skirs6 wrote:What are you trying to achieve? If it's just a bit more noise then try taking out the front silencers on OEM exhaust with straight pipes just gives a little more noise. I'm more than happy with results.
This is the same as my set up.
Plus small back silencers.
Sounds unreal....although boomy at speed.
Pops and backfires are ace.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Users browsing this forum: Google Adsense [Bot] and 35 guests
