HELP
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Prawn
HELP
Post by Prawn » Sun Mar 16, 2003 5:32 pm
Can anyone tell me how to get the pad retaining spring out of the Porsche 993tt calipers ?
Prawn
Joshie
Re: HELP
Post by Joshie » Sun Mar 16, 2003 7:18 pm
If your brakes are genuine Porsche 993 TT calipers then there is a spring clip which holds the pads in place. It is a long spring with a bow in the middle and is hinged at the bottom of the caliper and hooked at the top.
To remove, you need to compress the bow in the middle, which shortens the spring and allows it to be unhooked from the top of the calliper.
To remove the pads push laterally to and fro on the disk, which moves the pistons back a little way and frees the pressure on the pads. Use pliers to pull the pads free.
To make it easier to refit the pads use a lever to push the pistons back. Remember that there are two pistons for each pad and therefore the pistons need to be pushed back in unison. Don’t forget to make sure that the slack is taken up on the brake pedal before taking to the road.
There are a number of different designs made by Brembo and therefore your calipers may be different. and so perhaps johneroberts or andiroo will be able to advise you further.
johneroberts
Re: HELP
Post by johneroberts » Sun Mar 16, 2003 10:18 pm
monos or standard?
jr
Driving is believing
RS246 Founder
Prawn
Re: HELP
Post by Prawn » Mon Mar 17, 2003 10:08 am
Cheers guys,
I managed to figure it out in the end, the calipers have the hinged wire clip.
This just needs to be pushed to one side to release it from the top of the caliper.
Prawn
Users browsing this forum: No registered users and 72 guests
