Ridiculously hard ride
pimpinyourmum
Post by pimpinyourmum » Tue Jun 03, 2014 8:06 am
I'm hoping you guys can help. My RS6 saloon suffers from a ridiculously harsh ride. It's running KW V3's I believe although the previous owner fitted them from a car which had suffered an engine fire as far as I can gather.
At any rate the ride is appalling. I'm running standard 19" wheels but have considered downgrading to 18's just to soften it but I know I wouldn't be tackling the problem.
My local garage has softened off the springing but the harshness is still there over potholes and broken surfaces. I now have a softly sprung car that sort of 'bobs' over undulations and still crashes into bumps!!
I wondered if it was a damping issue but I'm told by the garage they can't see where to soften off the dampers???
Is there anything else I should be looking for?
Hoping you can help as it's totally ruining the enjoyment I get from the 6 - I actually avoid driving it at the minute.
Just to say I'm not being soft when I say the ride is harsh. My daily driver is a MINI GP with the coilovers wound down to maximum drop and I consider that ride to me more than acceptable :)
09 RS6 C6 Avant
Too many classic/modern classics
Re: Ridiculously hard ride
Post by Shoppinit » Tue Jun 03, 2014 8:37 am
Springiness? Eh? What did they do exactly?
The KW V3 need to be removed from the car for a proper adjustment. I know. Stoopid, innit? There's a thread in the stickies about people's settings.
Post by bam_bam » Tue Jun 03, 2014 10:04 am
There was a thread on RS6.com that showed how to make your KWs adjustable while in situ, however, it did involve cutting holes in your chassis and top mounts. Speaking of top mounts, do you know if the previous owner replaced theirs at the time of KW install?
saulcupra
Post by saulcupra » Tue Jun 03, 2014 11:20 am
Im running on pss9's and find a similar thing, im going to raise it a bit to give the spring a bit more travel, and check what settings the dampers are on.
I think I will end up taking them off, replacing the top mounts and then get bilstein to refurbish the units
I have also just had the lower arms and cv boots done
pimpinyourmum
Post by pimpinyourmum » Tue Jun 03, 2014 2:57 pm
Shoppinit wrote:Springiness? Eh? What did they do exactly?
Ahhhh, they need to come off do they??
So our view is that the V3's shouldn't be too harsh if set up correctly? If that's the view I will happily pay the garage to whip them off and have a go at resetting them!
09 RS6 C6 Avant
amanda1
Post by amanda1 » Tue Jun 03, 2014 4:05 pm
I run kW v3's on my 6 whilst they are firm,hmmm very firm I don't class them as harsh :assflash:
Make sure they are on the correct sides as well as the English don't seem to understand left ( links)and right (richts)in German!!!
950 nm torque!
amanda1
Post by amanda1 » Tue Jun 03, 2014 4:06 pm
Double post for some reason!!
950 nm torque!
IanH755
Post by IanH755 » Tue Jun 03, 2014 4:42 pm
After a quick passenger ride with Amanda I think her setup felt just right for the roads around Oxford, firm but not crashy over bumps.
pimpinyourmum
Post by pimpinyourmum » Tue Jun 03, 2014 5:14 pm
IanH755 wrote:After a quick passenger ride with Amanda I think her setup felt just right for the roads around Oxford, firm but not crashy over bumps.
Thanks - that's useful.
Amanda is your set up on the stickie?
09 RS6 C6 Avant
amanda1
Post by amanda1 » Tue Jun 03, 2014 5:21 pm
No it isn't, i do however have it in my service file which I am desperately looking for to confirm before I post :bash:
950 nm torque!
amanda1
Post by amanda1 » Tue Jun 03, 2014 5:40 pm
I think mine is 7 or 9 clicks on the rebound.....fwiw I would not swop my kw's for any other set up :assflash:
As you can see she's nice and low on those kw's :bigblink:
950 nm torque!
ahoooga
Post by ahoooga » Tue Jun 03, 2014 6:01 pm
Are you sure its not low because of the weight of your handbag you've left on the roof in the picture :jump_clap:
amanda1
Post by amanda1 » Tue Jun 03, 2014 6:09 pm
ahoooga wrote:Are you sure its not low because of the weight of your handbag you've left on the roof in the picture :jump_clap:
Yes positive ...........my handbag was empty :bigwave:
A more recent one then without the handbag ;)
950 nm torque!
pimpinyourmum
Post by pimpinyourmum » Tue Jun 03, 2014 6:15 pm
Thanks Amanda.
Is that 7-9 clicks from min or from max?
I'm presuming ride height won't have a massive effect on 'crashiness'?
09 RS6 C6 Avant
rossi46
Post by rossi46 » Tue Jun 03, 2014 6:22 pm
If too low then the spring will be very compressed - guess it'd need a certain window of travel otherwise it'd be like having 1000lb springs and 'crashiness' would result ??
Users browsing this forum: Google [Bot] and 118 guests
