Newbie brakes, exhaust and ECU
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
droberts
Post by droberts » Fri Jan 28, 2005 10:01 pm
UKS4APR1 wrote:I also have fitted the Stoptechs, IMO they are your solution.
Thanks, I've pretty much decided on the Stoptechs. I'm just waiting for Stasis to get back with some technical info (anyone know the brake bias using 13" Track Sport Front and 298mm Track Sport Rear).
Amazing really how slow some of the tuner's are - AmD still haven't got back to me (I asked for a quote on brakes, ECU and exhaust on Monday!) Thought they'd be biting my hand off - but must have bigger RS4 fish to fry :o
jeffw
Post by jeffw » Fri Jan 28, 2005 11:24 pm
My K04ed S4 produces substantially more torque across the rev range than when it was a remapped K03 version. You need to drive a K04ed S4 to appreciate the difference.
KayGee
Post by KayGee » Sat Jan 29, 2005 12:26 am
RE: Brake bias checkout ECS website. Great article on their explains the calculation. Should be enough for you to do the maths. Or get at least have an educated guess.
Jeff you got any dyno plots I can look at? You're running the K04s+FPR+chip, intercoolers?
jeffw
Post by jeffw » Sat Jan 29, 2005 8:47 am
Mine is K04s, remap and full Milltek (it's a 400BHP AmD conversion.....) and no RS4 intercoolers, fuel system or MAF/Airbox. It's probable best if I don't post dyno plots until I've visited AmD on Monday as there may be something wrong with the car.
droberts
Post by droberts » Sat Jan 29, 2005 10:48 am
KayGee wrote:RE: Brake bias checkout ECS website. Great article on their explains the calculation. Should be enough for you to do the maths. Or get at least have an educated guess.
Thanks KayGee, I previously skipped the formulae and went straight to the pdf :oops: . Assuming Stasis use the same hats for the rear and front, I calculate the brake bias 67:33; using the standard rear discs gives 71.5 : 28.5. I guess the rear upgrade should only be used with 355+ fronts.
jeffw
Post by jeffw » Sat Jan 29, 2005 10:59 am
I think 335 is the largest size you'll get under 17" rims...you'll need 18" for 355.
KayGee
Post by KayGee » Sat Jan 29, 2005 11:08 am
You have to be carefull with what rims you purchase as well. The Avus rims have lots of internal clearance.
moktoya
Post by moktoya » Sun Jan 30, 2005 4:56 pm
So jeff you're running K04 and Milltek with the rest of the hardware completely stock S4? So the remap is custom for your setup. Are u in the pipeline for something bigger? or this is the setup you're happy with for the long run? I ask a cos i was under the impression that without mods to the fuelling side the car will starve for fuel which is not sustainable in the long run, esp if one pushes his car hard and often. Rgds.
00 Imola B5 S4
S2tuner
Trader (Expired)
Post by S2tuner » Sun Jan 30, 2005 4:58 pm
Yup, agreed with moktoya, the S4 fuelling system is not good for 350+ HP...
HTH,
Mihnea
Users browsing this forum: Majestic-12 [Bot] and 75 guests
