Engine warm up...
4.2 V8 32v FSI - 444 bhp
smudge
Engine warm up...
Post by smudge » Fri May 16, 2014 12:11 am
Am I the only one who likes to stand outside the car when it warms up & eventually reaches that point where the engine makes a wop wop wop sound before dropping the revs?
:bowdown:
It's all torque talk.
Brooner
Re: Engine warm up...
Post by Brooner » Fri May 16, 2014 7:39 am
dont do it intenionly but by the time i drive it out of the garage and get out to shut the door again it does the wop wop noise :biggrin3:
Jordan100200
Post by Jordan100200 » Fri May 16, 2014 3:36 pm
Someone should put a video on of this
Eatpies99
Post by Eatpies99 » Fri May 16, 2014 7:57 pm
Jordan100200 wrote:Someone should put a video on of this
Agreed
smudge
Post by smudge » Mon May 19, 2014 9:30 am
I'll do a before & after once my exhaust has been replaced......
eightfoot
Post by eightfoot » Mon May 19, 2014 3:23 pm
smudge wrote:I'll do a before & after once my exhaust has been replaced......
dont see what the difference would be as the sound comes from the engine bay/secondary air valve bypass :bigblink:
smudge
Post by smudge » Mon May 19, 2014 3:37 pm
I'm not putting the stock zorst back on, so I would think the overall tone of the system will be different no?
Graeme4130
Post by Graeme4130 » Mon May 19, 2014 4:30 pm
I always wondered why the noise was different for the first 20 or so seconds
What's the reason for it doing that ?
eightfoot
Post by eightfoot » Mon May 19, 2014 4:48 pm
when you first start up the valves in the exhaust are open as they run on engine vacuum,fast idle produces no vac untill it goes down off fast idle then then valves close as does the secondary air bypass thats when you hear the fluffing noise as the idle comes down and the vacuum increases closing the exhaust valves and the variable inlet vanes and the secondary air system which helps with the cats warming up by blowing air into the exhaust (but dont quote me as i'm no expert) :roll:
Graeme4130
Post by Graeme4130 » Mon May 19, 2014 5:15 pm
Cool, cheers
They always sound much better first thing in the morning. Just a shame you can't boot the freezing cold engine to hear what it'd sound like under power at high revs with everything open
eightfoot
Post by eightfoot » Mon May 19, 2014 5:23 pm
Graeme4130 wrote:Cool, cheers
put the gearbox in sport will open the valves or select individual in the mmi car settings and set engine noise to dynamic,think mine is comfort engine,auto everything else,dynamic engine sound,dont think reving it stationary will open the intake vanes thou but you should hear them at about 4000ish rpm as you get increased induction noise
carsarecool
Post by carsarecool » Tue May 27, 2014 5:44 pm
Replaced?
Macdaddy
Post by Macdaddy » Thu May 29, 2014 8:48 am
Does the B8 still limit the revs when cold like the B7 did?
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
Graeme4130
Post by Graeme4130 » Thu May 29, 2014 10:45 am
Macdaddy wrote:Does the B8 still limit the revs when cold like the B7 did?
It does, yeah
It'll just change up at 4ish rather than hitting a limiter
smudge
Post by smudge » Thu May 29, 2014 11:19 am
Replaced?
:sekret:
Users browsing this forum: Google [Bot] and 69 guests
