Trups
- Trader (Expired)
Post
by Trups » Mon May 05, 2014 3:45 pm
leadfoot wrote:Forgot to mention... The inclusion of the screws was icing on the cake.. As mine were stripped and had to be dremmel the last LED off the car. The screws are torx and fit better and are better quality than the OEM ones.
They are Also an Audi Part
Trups
RossDagley
- Top Gear
Post
by RossDagley » Fri May 09, 2014 1:54 pm
Just bumping this for trups - now ordered again from him. Sidelights this time
Thanks!
Previously:
Spectre
Post
by Spectre » Fri May 09, 2014 11:51 pm
Just had the whole interior replaced - looks ace... just need you to sort out that numberplate error now Trups!
2013 Guards Red 991 Carrera - VERY MUCH Arrived.
2013 Ibis White RS4 B8 - Gone
2007 Phantom Black Avant RS4 B7 - Gone
sync24
- 5th Gear
Post
by sync24 » Wed May 14, 2014 8:42 pm
All - a heads up.
If you have auto lights - the current model supplied not compatible and will throw an error. The only way to clear the error is to start the car with the lights of and then switch them to auto - not ideal.
Trups is aware and is working on a solution so I would hold off ordering if you have auto lights on your RS4.
AdrianD
Post
by AdrianD » Wed May 14, 2014 9:09 pm
Just to add that i bought the complete interior light kit from trups + number plate ones (I already had LED DRL) and i had a couple of minor snags with them, ok (i was crap at fitting them lol) and trups went above and beyond to help and i'm now fully LED'd up and a happy chappy. Fantastic service from beginning to end and a must have mod imo
2010 911 Turbo PDK.
Gone but not forgotten...
Sprint Blue B7 RS4 with all the toys
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
sync24
- 5th Gear
Post
by sync24 » Wed May 14, 2014 9:15 pm
+1 can't fault his service and I am sure he will come back with a great solution
neilparf
Post
by neilparf » Wed May 14, 2014 9:24 pm
I'll weigh in - I have auto lights and realised they do throw an error.
However, Trups is a sound sound sound bloke and top products and service. I've LED'd my entire car with Trups LEDs and they are simply top notch kit.
The plate LED I know he'll sort for auto lights...
Gone but never forgotten:
AdrianD
Post
by AdrianD » Wed May 14, 2014 9:39 pm
I thought all B7 RS4's had auto lights??
Anyways mine has and it's thrown up an error probably about twice since fitting but on both of those occasions it was for around 1/2 a second then clears itself straight away..
2010 911 Turbo PDK.
neilparf
Post
by neilparf » Wed May 14, 2014 9:44 pm
Auto lights are part of the tech pack £325 inc vat at the time(auto lights, adaptive lights, rain sensors, dimming mirror and coming home)which was an extra
Adrian - if you do what sync mentions previously it should start without any errors...
John Johnson
- 5th Gear
Post
by John Johnson » Wed May 14, 2014 10:55 pm
I ain't got auto lights and it's setting off mine too
Current toys in the garage
B7 avant in Daytona with ceramics and a few other goodies and lowwwww miles
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
neilparf
Post
by neilparf » Wed May 14, 2014 11:16 pm
John Johnson wrote:I ain't got auto lights and it's setting off mine too
Spectre
Post
by Spectre » Wed May 14, 2014 11:46 pm
Thanks for the update all... looking forward to finishing off my all round LED's once Trups figures this one out.
Mak.
AdrianD
Post
by AdrianD » Thu May 15, 2014 7:56 am
neilparf wrote:Auto lights are part of the tech pack £325 inc vat at the time(auto lights, adaptive lights, rain sensors, dimming mirror and coming home)which was an extra
Aha, i didn't realise that, thought it was standard kit...
I don't really get any errors on Auto Neil, only a couple of times and both of them it went out immediately... 99% of the time they're perfect...
2010 911 Turbo PDK.
neilparf
Post
by neilparf » Thu May 15, 2014 8:36 am
AdrianD wrote:neilparf wrote:I don't really get any errors on Auto Neil, only a couple of times and both of them it went out immediately... 99% of the time they're perfect...
That's pretty good Adrian - I think Trups would be concerned at throwing any errors maybe so hence him probably wanting to sort it 100%. Mine always throw an error when on Auto lights and admittedly it goes. Normally when it's dark and the Auto senses low light immediately at the diagnostic check or I override the Auto light. Auto on in the daytime through to night I'm sure to doesn't throw an error, obviously - it's finished it's checks then and the incandescent is taking the load...
Yeah - £325 for a few sensors to switch a few things!
Post
by MikeFish » Thu May 15, 2014 8:52 am
Don't forget the motors to make your lights looks side to side as well as up and down when you start the car.
Users browsing this forum: No registered users and 259 guests
