Spark plug intervals
2.2 I5 20v turbo - 315 bhp
alastairg
Post by alastairg » Mon Jan 24, 2005 12:15 pm
Standard RS2
3 years/40k or more often. What is the collected experience here ?
Oh and if I remap. Change more often ????
RS2 'an estate car named Desire'
GlynRS2
RE: Spark plug intervals
Post by GlynRS2 » Mon Jan 24, 2005 9:36 pm
I manage to get a set at GTI International for £5 each.
The car had only done about 6,000 miles on the previous set, but felt a little sharper when they were first replaced.
Didn't throw the old ones away as they were so new, but if can get the plugs at that price again I will probably change them every year.
Probably completely unecessary though.
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
scillyisles
Post by scillyisles » Mon Jan 24, 2005 9:44 pm
I've done 48K in mine since new (1995) and I've changed the spark plugs four times in 10 years. When you change them you immediately notice the difference with the engine running smoother and pulling much better. If you can't get them as cheap as Glyn suggests then I seem to recall that german and swedish stock them for not much more.
Audi RS2 - the original
hiltron
Post by hiltron » Tue Jan 25, 2005 10:43 am
When you accelerate full throttle under load ( Uphill.) if the car has a slight splutter at top end of revs. 5-6000rpm. Time to change plugs.
95. RS2 RHDrive. Polar Silver. Stock Standard
alastairg
Post by alastairg » Tue Jan 25, 2005 5:31 pm
No splutter :D
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Jan 25, 2005 9:27 pm
I would replace them once a year - every second service. Check they are torqued correctly - they are famous for coming loose.
http://www.MRCtuning.com
alastairg
Post by alastairg » Fri Jan 28, 2005 11:07 am
Done and as scillyisles says the car is sharper. Will go to annual changes
Return to “RS2 (B4) 1994-1995”
