Auxiliary Radiators
NJMAudiRS4
Auxiliary Radiators
Post by NJMAudiRS4 » Thu May 01, 2014 8:10 am
Does anyone know of a company that produces an all alloy auxiliary radiator for a B7 RS4, or does anyone have the exact dimensions (picture would be helpful) so that I could get one made or do I just buy a genuine part.
Any help appreciated
Nick
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
neilparf
Re: Auxiliary Radiators
Post by neilparf » Thu May 01, 2014 8:26 am
Nick - I know JCWF do radiators (albeit bespoke), not sure if they have produced RS4's though...
Gone but never forgotten:
NJMAudiRS4
Post by NJMAudiRS4 » Thu May 01, 2014 8:40 am
Thanks Neil, will have a chat with them
neilparf
Post by neilparf » Thu May 01, 2014 11:15 am
NJMAudiRS4 wrote:Thanks Neil, will have a chat with them
They were doing some Lancia rally Rad's when I was there having mine - looked seriously good quality. Good luck.
'R'e'S'pect_4
Post by 'R'e'S'pect_4 » Thu May 01, 2014 12:35 pm
I replaced mine with genuine ones. got them for £160 each IIRC.
Is poor they only last 50k, but where they are located doesnt help.
I did keep my old ones for a while, but been binned now, probably best get hold of one for them to consider making.
at least both sides are identical.
...here is who i got them off £185 now..... good guy to deal with (audi main dealer!)
http://www.ebay.co.uk/itm/Genuine-Audi- ... 537wt_1161
neilparf
Post by neilparf » Thu May 01, 2014 12:45 pm
'R'e'S'pect_4 wrote:I replaced mine with genuine ones. got them for £160 each IIRC.
No brainer - at that money I doubt anyone could make from scratch a replacement alloy version....
I'll bookmark that ebay link!
'R'e'S'pect_4
Post by 'R'e'S'pect_4 » Thu May 01, 2014 2:04 pm
Yeah, pretty resonable.
I had one leaking, replaced it, cleaned up other one before refit bumper, and removing dirt from second one it started weeping, so off it came also! easy to do if you are having a go.
Reccomend you get the 'G' type pipe clamps for the coolant hoses.
They are good quality IMO, just the location in line of fire of stones, etc... are their downfall.
neilparf
Post by neilparf » Thu May 01, 2014 2:06 pm
Nice tip - cheers...
John Johnson
Post by John Johnson » Thu May 01, 2014 2:21 pm
I've just done mine , full fat retail was £201,kept the old ones which had just started to slightly weep incase I can get em refurbed ( Christ knows why ) same unit as on a Ttrs too
Current toys in the garage
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
NJMAudiRS4
Post by NJMAudiRS4 » Thu May 01, 2014 10:11 pm
Cheers fellas, will get an original then, thanks for the advice
John Johnson
Post by John Johnson » Thu May 01, 2014 10:25 pm
One on the bay at £139
Rs1600i
Post by MikeFish » Thu May 01, 2014 11:24 pm
Passenger side prone to failure due to collection of leaves and other dirt. Change the passenger one for a new one (should see you out till the end.of your ownership at least. Get the drivers side removed and hhave a cold air feed fitted in its place. Then you only have 1 to worry about after that.
NJMAudiRS4
Post by NJMAudiRS4 » Fri May 02, 2014 8:34 am
That is the plan, delete Driver's side rad and replace passenger side. With regards to the cold air feed, do I just plumb a pipe through upto air box, and that's it or are there more technical things to do ?
Thanks John did not see that one will have a look, I've seen the genuine brand new one for £185
Thanks to all
Nick
NJMAudiRS4
Post by NJMAudiRS4 » Fri May 02, 2014 9:58 am
Bought brand new Rad from Aberdeen Audi via eBay
John Johnson thanks for letting me know about the eBay item for £139 but it is not a genuine rad, the fittings and locators are all wrong, but thanks anyway
Does any one know how easy it is to bleed the cooling system, the stealers have quoted 3hrs to replace rads and 1hr to bleed the system, I don't recall it taking an hour for any engine to get upto temp ?
Any advise would be appreciated
Nick
PetrolDave
Post by PetrolDave » Fri May 02, 2014 2:51 pm
MikeFish wrote:Passenger side prone to failure due to collection of leaves and other dirt.
When I had an aux rad fail due to corrosion at the base of the rad 4 years ago it was the drivers side not the passenger side.
Both sides have the same bad design that allows dirt,leaves, etc to accumulate.
Users browsing this forum: No registered users and 206 guests
