New DV's = Odd Noise
saulcupra
Post by saulcupra » Tue Apr 29, 2014 11:46 am
Morning all
Had my car serviced and health checked at Unit 20 last week (oil/filters/Box/Diffs) all ok and no errors anywhere (bar a leak from oil cooler and weepy RMOS)
I fitted some new panel filters over w/end, all fine.
Then I replaced the Forge/CC DV's (Yellow Spring) with stock 710N units.
Now, on light/half throttle at 2-3K I get a weird noise, bit like a kazoo blown by an asthmatic, or maybe a resonance type noise.
Im presuming its something to do with the new DV's, ive searched and read a comment by Grizz that the 710N's can make a strange noise on the RS6.
Anyone care to enlighten me? The old Forge DV's are filthy, I have my gun cleaning oils etc so ill give them the once over if I need to put them back on.
NB Car is mapped by unknown at the moment, we think its a piggy back or new eeprom that's been put on as it wont take a new Revo map over the top.
This will be sorted sooon with new eeprom properly fitted.
TIA :beerchug:
IanH755
Re: New DV's = Odd Noise
Post by IanH755 » Tue Apr 29, 2014 3:26 pm
Have a look at this thread as I also replaced my DV's, air fters etc and get a strange noise - http://forum.rs246.com/viewtopic.php?f=2&t=109261
Post by Shoppinit » Tue Apr 29, 2014 4:23 pm
Usually it's the forge DVs that make the honking noises.
Could it be fluttering that you're hearing? Maybe there's a vac leak somewhere or you've got a faulty N249.
saulcupra
Post by saulcupra » Tue Apr 29, 2014 5:51 pm
its hard to explain (what noises aren't)
there was no noise with the forge ones on, will try and get a recording
unless ive pulled a hose somewhere, but power seems as was before
Post by Shoppinit » Tue Apr 29, 2014 5:56 pm
I'm wondering if the problem isn't downstream of the DVs. Maybe the forge ones weren't working (seized?) and you didn't know it (wouldn't necessarily affect the absolute power you make - more of an issue for gear changes). Clean up and lube the forge ones to see if once working you get the same noise.
A recording would be good.
saulcupra
Post by saulcupra » Tue Apr 29, 2014 9:31 pm
EDIT
got it as an mp3 or a 3ga file, but cant find anywhere to hose it?
any ideas?
soundclip (if the link works) 6 seconds in, then a little bit after that also
IanH755
Post by IanH755 » Tue Apr 29, 2014 10:12 pm
Wouldn't play for me (Media player or VLC).
ahoooga
Post by ahoooga » Tue Apr 29, 2014 10:33 pm
I got the following from that link :bigblink:
IanH755
Post by IanH755 » Tue Apr 29, 2014 11:08 pm
I'm uploaded a vid of the noise my car makes into my thread above if you want to compare.
saulcupra
Post by saulcupra » Tue Apr 29, 2014 11:11 pm
edited above post to remove the link
ian, sounds very similar to mine!
can email you the file if you want?
saulcupra
Post by saulcupra » Wed Apr 30, 2014 9:28 pm
thanks to ian for hosting!
6 seconds in
www.ianhenshall.com/moose2.mp3
saulcupra
Post by saulcupra » Tue May 06, 2014 8:47 am
cleaned, re-greased and re-fitted the forge DV's and sound has disappeared
odd but I suspect not threatening!
Post by Shoppinit » Tue May 06, 2014 12:53 pm
Maybe that's why the RS6 uses the 710P instead of the 710N. I've always wondered what the exact difference is (if any).
sweegie
Post by sweegie » Tue May 06, 2014 1:36 pm
The 710N has a stronger spring at the very least, but I'm not to sure on other construction differences.
FWIW I put 710N's on my car and have had honking noises at light loads ever since. The new 710N's are made by Keyser, not Bosch, and don't suit the RS6 IMO. I had to play around quite a bit with the N249 settings to quieten things down. 710P's will be going back on the car shortly.
HTH
Recycling dinosaurs for fun
Post by Shoppinit » Tue May 06, 2014 1:45 pm
Interesting. Maybe what people are hearing is flutter when the load conditions on the valve spring are borderline.
Users browsing this forum: 111marc111 and 85 guests
