Long time lurker. First time owner!
saulcupra
Post by saulcupra » Fri Apr 11, 2014 9:07 pm
Evening all.
After 10 years of lust for the big 6 I picked up R5 SKX yesterday.
I believe it used to belong to a fella on here, the bits he put on it are still on it from what I can see.
Its been a tad neglected but its still in ok nick and I think I paid a decent price for it.
Foibles so far.
Hvac temp changing from degrees c to f randomly, rns e retro fitted
Graunch/judder when turming right on near full lock
Slight whistle from the power steering on full lock either side
01119 fault code
Passenger door bouncing off the lock if shut too hard
Any advice gratefully received!
mavada
Re: Long time lurker. First time owner!
Post by mavada » Fri Apr 11, 2014 9:15 pm
FON :thumbs:
Code 01119 = Gear Recognition Signal
Probably your abs light is on to?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Sat Apr 12, 2014 10:24 am
Congrats, Saul.
Get that car tip top.
The whine is probably normal on full lock.
The judder probably is, too. The Quattro diff doesn't like full lock.
The gear recognition signal sounds like a F125 fault. Fairly common. No biggy.
FON
saulcupra
Post by saulcupra » Sat Apr 12, 2014 2:01 pm
Cheers lads, going to take some time but I think thats half the fun!
Mav, no abs light on and no errors in engine or trans modules.
Going to take it to unit 20 for fluids service and health check next week to see the extent of what needs doing!
Also get the ecu flashed to stock to give me a base line to work fron as the boost requests are a bit all over the place!
EcurieEcosse
Post by EcurieEcosse » Sat Apr 12, 2014 3:55 pm
Congratulations! I've just bought one too - fantastic cars!
Post by chunky79 » Sat Apr 12, 2014 4:12 pm
Welcome to the fold.
Rule 1.
amanda1
Post by amanda1 » Sat Apr 12, 2014 4:42 pm
saulcupra wrote:Cheers lads, going to take some time but I think thats half the fun!
Well done and as said rule 1 :)
Oh keep an eye out for me as that my stomping ground ;)
950 nm torque!
sulli
Post by sulli » Sat Apr 12, 2014 6:04 pm
Saw the car locally to me in cov a couple of times. I thought it was up a little cheap but the faults explain that. Get it tip top and you have an awesome spec car in the best colour :beerchug:
Is it remapped?
Daytona RS6 saloon, KW v3s, Hotchkiss ARBs, Milltech non res, MRC
CI Granduca Motorhome!
Post by bam_bam » Sat Apr 12, 2014 8:22 pm
FON.
Rule 1.
Welcome, mate.
saulcupra
Post by saulcupra » Sun Apr 13, 2014 6:48 pm
Rule 1
audi_driver79
Post by audi_driver79 » Mon Apr 14, 2014 2:06 am
Don't look for problems, they find you! Looks great...
C5 RS6 Avant Mugello Blue, Original Springs.
2001 A2 1.4tdi 75bhp. Runs on fresh air!
Dunkx
Post by Dunkx » Mon Apr 14, 2014 8:08 pm
Welcome Saul. The door lock bounce thing probably means the lock mechanism is on the way out. I've had both of mine replaced in the last year as they started doing that (one of them today!) by Martin and Lee @ Unit 20. They'll sort you out. D
saulcupra
Post by saulcupra » Tue Apr 15, 2014 9:52 am
Thanks Dunkx
Thought it would be the mechanism, a breaker on ebay is flogging passenger and drive side for circa £35 each
Worth a punt maybe?
Can you remember what you paid to have yours fixed/replaced?
Dunkx
Post by Dunkx » Tue Apr 15, 2014 10:02 am
I can - I have the receipt in front of me as one was done yesterday! The lock mechanism was £125.18+vat and the fitting was £55+vat.
Post by chunky79 » Tue Apr 15, 2014 11:07 am
Don't bother buying from a breaker, they will probably be as bad as the one your changing. Get new, they won't break the bank, and if they do, well, you're screwed.
Users browsing this forum: B_O_N_K and 74 guests
