In need a a mechanic to fit a boost guage in w.london?
Does anyone have a contact in West London area or near who can fit a boost guage? I have the guage and pillar holder. All i need is a fitter?
RE: In need a a mechanic to fit a boost guage in w.london?
can you not do it yourself ?
only ask because i've just installed one over the weekend, and believe me, if I can do it, anyone can.
Hi Olly,
Yeah i was thinking about doing it myself but i'm just to busy. I got it done now at http://www.autoperfections.co.uk/
There very helpful. They also fitted to my cliff alarm the button start. Its great as now i turn my car on from flat. Gives the turbos a few minutes to warm up and cool down.
I'm loving my S4!!
Regards,
Jay
I'm loving my S4!!
Regards,
Jay
RE: Cheers
cool, good stuff. yeah i've been thinking about a remote start system for a while now, although the S4 does seem to warm up quite quickly !
RE: Cheers
apparently the oil pressure at idle isn't sufficient to prevent bore and bearing wear. The users manual thing
suggests that you pull off immediately after starting up.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Remote control start
Is nice getting in your car and all the windows are already defrosted and your heater is nice and warm. Beats them cold mornings. I would recomend it.
RE: Remote control start
As JonnyX says, that is not good for the car.
You should get in, start it and move off immediately and drive gently until the oil temp hits 90.
This will minimise the warm-up time and therefore the engine wear, 70% of which occurs during warm-up.
Start
Hmmmm,
Thanks for that info. I was always advised to let the oil warm up before driving. In that case i'll make sure that i don't let it run for to long without moving.
What about when you finished driving the car? (after booting it)??? Is the audi different then skyline, suburu setups???They come with turbo timers?
Most appreciate the info.
Jay
Jay
RE: Start
2-3 minutes of gentle driving/tickover should be enough to cool the turbo bearings and leave them with cooler oil when turned off. I just drive the last 5 minutes gently then switch off.
No turbo timers on Audi's but the turbo bearing housings are water cooled. Not sure how much that helps though !
Users browsing this forum: Majestic-12 [Bot] and 75 guests
