Very close call!
Very close call!
On my way home tonight,i noticed that the temp display was showing 2*c so i backed off the throttle to around 60mph.
As i started my turn into a left bend,the back end of the car suddenly let go resulting in the car going almost sideways up the luckily deserted country road.
I tried to correct the car using only the steering wheel and after about 4 or 5 secs i managed to bring the car back under control.
During the time the car was snakeing from left to right i managed to glance and noticed that the esp indicator remained off!
I thought the ESP would have jumped into life braking the relevent wheel or wheels,but it really felt like i was having to do all the work after hitting a long stretch of black ice?
After i had proper control over the car i applied the brakes as hard as i could and the car went into a slid,i felt the ABS kick in but again no ESP light flashed.
Is this normal,as i must confess this is the first time my arse has gone proper in the car???
Cheers fc
Cheers fc
If you were not accelerating by means of applying the go faster pedal then I don't think the ESP would kick in.
The only time I felt the ESP kick in was going fast round a bend with me having me foot down on the gas. Dectecting slip, the ESP light came, notice the weird sensation someone else braking for me (with me still on the gas)- which I lifted off and thought what the....
Therefore I think it would only kick in by braking when your trying to accelerate on purpose, as I have described above.
Only other time is accelerating straight, hit a pot hole; that particualr trye had no contact with the ground and the ESP light came on.
I assume while you were snaking, you lifted off the gas (1st natural thing to do?) so the ESP can't brake/ help you out as this point in time for you.
No sig, no RS4 anymore
Not so odd, The ESP will usually only light up when under power, you were for all intensive purposes, free wheeling if you did not apply throttle or brakes. When you did apply the brakes the ABS would do its stuff, but the ESP would still be doing nothing, had you applied full throttle once the car was under control, it would have lit up if it detected wheel spin....
Generally Traction Control works via the wheel speed sensors for the ABS, and only acts to conteract slip. The majority work via a soft ignition or fuel cut. So yes they will generally only work under power, I have no working knowledge of the Audi ESP though.
My ESP seems to kick in almost every time I overtake in 2nd or 3rd. I guess it could be partly due to the greasy Peak District roads and partly that the straights are short (so you've got to go for it quickly) but does anyone else have this regularly - or am I just too heavy on the gas???kennyboy wrote:The only time I felt the ESP kick in was going fast round a bend with me having me foot down on the gas. Dectecting slip, the ESP light came, notice the weird sensation someone else braking for me (with me still on the gas)- which I lifted off and thought what the....
Kenny,i did take my foot off all the pedals once the car was out of my control as i felt like the right thing at the time to do.
RS4ge i often manage to light the ESP indicator during overtaking in almost all the gears,usually on the type of road conditions you describe.
Just checked the roads about half hour ago,black ice everywhere
Cheers fc
Cheers fc
I have had ESP come in twice now (with associated wheel braking). Once was under power whjere it was understeering too much due to the negative camber (by Tescos' there Ken!) and it braked the rear offside to swing car round. The other time was yesterday when i was flat out in second 'straightening' a roundabout but there was a dip in the road and I guess tyres left the ground. Bloody heartstopping both of them as it's like the unexpected hand of God when the wheels chirp!!!
AMD III RS4
Dunno about a write up, but it works by taking inputs from things like steering angle, throttle and brake position etc and combines it with longitudinal and lateral acceleration measurements (sensor for this is under one of the front seats). From these, it decides if the car is sliding too much and takes control of throttle and individual wheel braking to attempt to get the car to do what the drivers phyiscal inputs are requesting.
My understanding is that ESP will kick in during loss of traction under accelleration and during excessive yaw.
I assume in the case of black ice there is no excessive yaw due to a 'frictionless' slide, so the ESP probably doesn't know any better.
In such cases I'd be braking as hard as I can, atleast that way the ABS and EBD can do their work.
Traction control = wheelspin prevention
ESP = Stability (slide) management. The system will always know when the car is slided because it is measuring longitudinal and lateral acceleration and combining them with other inputs then comparing with stored maps.
Example:
Car is doing 30 mph, half turn of left lock, and 0.0g of lateral acceleration i.e. going straight on. The car is sliding. This is very simplistic but it illustrates how the system works.
Example:
ABS doesn't work so good on significant amounts of ice. I have had times when slamming on the anchors results in all four wheels locking quickly enough for the ABS system to just think I am stopped - ie, no differences between wheel speeds. The result is a locked up car sliding merrily on its way. I have had this in VW and Audi cars, and it takes you by surprise first time as you kind of assume that ABS will save the day when in fact it makes it worse (if you are conditioned to leaving your foot on the brake as per ABS instructions)
Users browsing this forum: No registered users and 144 guests
