Question to RS owners - brake dust on alloys
WilkinsonRS4
I'm running an RS4 B7 with the Brembo upgraded brake kit on with Yellow Stuff pads.
I get loads of brake dust even just after a good wash and I'm wondering if you have come across any products to put on alloys to make brake dust easier to clean and which maybe disperses brake dust off alloys after applying??
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
Re: Question to RS owners - brake dust on alloys
I use g-techniq C5alloy wheel sealant. Lasts for about a year and definitely helps the brake dust to come off in each wash. Coats about £23 from ultimate finish.
Gone and miss very much
B7 RS4 Avant Misano Red, lepsons 2-tone black shadow chrome rims, KW coilovers, AMD Stage-1 with valved non-res milltek catback.
Autoglym seal
Just don't spray it on - much better to either do with wheel off or spray on a cloth and wipe on
Massive +1 on this. Use it in mine. Best way is wheels off and give it a full coat. I've found Bilt Hamber wheel clean is kind to the coating...Ginors4 wrote:I use g-techniq C5alloy wheel sealant. Lasts for about a year and definitely helps the brake dust to come off in each wash. Coats about £23 from ultimate finish.
Gone but never forgotten:
Poorboys Wheel Sealant for me. Has worked well on my winters and summers - both sets fully refurbished recently. When they come off I give them a clean-up with Autoglym Super Resin Polish, and before they go back on I apply two or three layers of Poorboys.
I'm in the same situation have some wheels on the way want to get them sealed up nice, I'm following carbon collective on Instagram and there wheel sealer looks impressive was going to give it a go.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
- DaytonaRs4
i use my auto finesse touch coat paint sealant on mine, rub on with sponge leave to cure then buff off, it is obv meant for paintwork sealing but does a great job sealing the wheels too
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
WilkinsonRS4
This looks good stuff I will try this thanks mate!!Ginors4 wrote:I use g-techniq C5alloy wheel sealant. Lasts for about a year and definitely helps the brake dust to come off in each wash. Coats about £23 from ultimate finish.
+2neilparf wrote:Massive +1 on this. Use it in mine. Best way is wheels off and give it a full coat. I've found Bilt Hamber wheel clean is kind to the coating...Ginors4 wrote:I use g-techniq C5alloy wheel sealant. Lasts for about a year and definitely helps the brake dust to come off in each wash. Coats about £23 from ultimate finish.
Used it on mine too, can normally blast it off with the jet wash after applying bilberry safe wheel cleaner. If its been more than a week between washing just a quick wipe and its gone.
A sealant or quality wax. I have used both AutoGlym sealant and Swissvax Autobahn wax.
I ftted EBC red stuff because these don't create brake dust like yellow stuff pads.
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
My only issue with red stuffs is that they are much softer than yellow stuff and I suspect OEM. As a road pad they are fine but I wouldn't want to use them on track.rob-s wrote:A sealant or quality wax. I have used both AutoGlym sealant and Swissvax Autobahn wax.
Sorry to take this off topic, but what is the Brembo upgrade? As far as I can tell from the photo, that caliper and disk is identical to the calipers on my B7 (other than its yellow). Which is no surprise as the stock caliper is made by Brembo.
There's a company I follow on Instagram, carbon collective, the sealant products they have look amazing, I've ordered wheel,glass and other sealants so hopefully results will be good, website is well worth a look.
Much like Gtechniq...ss378008 wrote:There's a company I follow on Instagram, carbon collective, the sealant products they have look amazing, I've ordered wheel,glass and other sealants so hopefully results will be good, website is well worth a look.
neilparf wrote:Much like Gtechniq...ss378008 wrote:There's a company I follow on Instagram, carbon collective, the sealant products they have look amazing, I've ordered wheel,glass and other sealants so hopefully results will be good, website is well worth a look.
Yeah precisely, guess I should really pay more attention to detail.
Users browsing this forum: No registered users and 170 guests
