RNS-E AMI Upgrade
neilparf
Re: RNS-E AMI Upgrade
Post by neilparf » Thu Mar 13, 2014 11:21 pm
I'd roll that way too, Billy! Or send my 7 year old up the back to plug it in!
Gone but never forgotten:
PetrolDave
Post by PetrolDave » Fri Mar 14, 2014 6:17 pm
neilparf wrote:I'd roll that way too, Billy! Or send my 7 year old up the back to plug it in!
There's only 6 bolts to undo to remove the glovebox :boohoo:
neilparf
Post by neilparf » Fri Mar 14, 2014 6:24 pm
Its good practice for him for when he starts to clean Chimney's...
Mr Footlong
Post by Mr Footlong » Sat Mar 15, 2014 7:48 pm
Haven't coded it in yet but I had the old changer out, AMI in, cable run through from behind the head unit and it all fitted in well under 10 minutes :). No problems whatsoever snaking the AMI cable through but I also have gibbon-like hands which helped no doubt.
Current:
Gone:
V8mark
Post by V8mark » Sat Mar 15, 2014 10:00 pm
Just a quickie, can the ami interface play vids from the iphone? I didn't think it could just asking..... And yes I know search is my friend, but seeing as you are talking ami thought I'd ask :)
2006 RS4 Avant - Carbon Clean, Intake Ports Polished, HF Air Filter, MRC Remap
1998 Toyota Supra 3.0 TT - de-cat, bleed valve, UK Spec Brakes, HKS Springs & CW Dampers, Goodridge Lines, Pagid Pads & 360 RWHP
1990 Toyota Supra 3.0 T - de-cat, HKS Boost Controller (1.4 bar max), used as a daily drive for 110k miles on original turbo!
198x Granada 2.8i Ghia X - Can't remember the exact year - but a great car!
Mr Footlong
Post by Mr Footlong » Sat Mar 15, 2014 11:28 pm
Don't think it can but I am not an isheep user. Guys, still haven't coded it in yet but was out in the car tonight for about 30 mins after fitting it and I am getting engine feedback (rev interference noise if you follow) when playing SD media at the very least, may well affect radio too but most noticeable when fading out/in tracks. 99% sure it wasn't there before but may swap it all back to check.
Current:
Gone:
GlenRS
Post by GlenRS » Sun Mar 16, 2014 8:31 am
Possible that you have a bad earth somewhere.
Something I keep wondering and upgrading the head unit will be on my list to do at some point, I have the Audi I pod adapter in the glove box already. Will this work with the 2010 on head units and display all the ipod track and album listing, or will I still need this other ami interface?
PetrolDave
Post by PetrolDave » Sun Mar 16, 2014 11:26 am
V8mark wrote:Just a quickie, can the ami interface play vids from the iphone? I didn't think it could just asking..... And yes I know search is my friend, but seeing as you are talking ami thought I'd ask :)
I'm 99.99% sure it will play the audio, but it can't play the video as there's no video connection between the AMI and the RNS-E.
PetrolDave
Post by PetrolDave » Sun Mar 16, 2014 11:29 am
GlenRS wrote:Possible that you have a bad earth somewhere.
+1
GlenRS wrote:Something I keep wondering and upgrading the head unit will be on my list to do at some point, I have the Audi I pod adapter in the glove box already. Will this work with the 2010 on head units and display all the ipod track and album listing, or will I still need this other ami interface?
The Audi Ipod adapter is just a CD emulator, so it will work with the 2010+ RNS-E - but with exactly the same limitations as with a pre-2010 RNS-E (which is caused by Audi not implementing CD text over the CD changer interface (which was designed in the last millenium!). So if you want album and track info on the RNS-E screen then you have to go down the AMI route.
Mr Footlong
Post by Mr Footlong » Sun Mar 16, 2014 1:06 pm
I thought so as well thanks. Haven't removed the kit to check yet but I recoded it all this morning.I have recoded to 0309725 as I have removed both the CD Changer and the useless TV Tuner from the boot. I was pretty sure that based on the on-screen instructions I got the right number but looking at the wiki now has me doubting myself. The AMI now appears in the sources (I don't have any iSheep devices to check that currently) but I guess I should go double check the steering wheel functions.
Current:
Gone:
Rw@@dy
Post by Rw@@dy » Sun Mar 16, 2014 2:16 pm
PetrolDave wrote:
neilparf wrote:Nice one, Billy. You don't need to remove the glove box I don't think - just remove the cd changer using the radio keys I've read on another forum. Sure PetrolDave could confirm...
The AMI doesn't use the same lead as the CD changer so you have to run a new lead from the back of the RNS-E to the glovebox - and that's a whole lot easier if you remove the glovebox, unless you're double jointed :biggrin2:
Does anyone have a link to this cable?
Billy
Post by Billy » Sun Mar 16, 2014 3:34 pm
This is what you need mate.
http://www.kufatec.co.uk/shop/en/audi/a ... audi-a3-8p
Rw@@dy
Post by Rw@@dy » Sun Mar 16, 2014 4:33 pm
GlenRS
Post by GlenRS » Sun Mar 16, 2014 5:52 pm
So on that basis would just getting the ami make the ipod work properly with the original head unit and give proper directory access? Or would it still not and hence the upgrade to the newer unit?
Ultimately im happy with the head unit I have, just drives me potty the ipod functions are beyond useless.
Billy
Post by Billy » Sun Mar 16, 2014 5:56 pm
You'll need a 2010+ RNS-E if you want to use AMI mate.
I was happy enough with my original but it's just out of date for what I wanted to do unfortunately.
Users browsing this forum: No registered users and 259 guests
