8mm h&r spacers vibrations
CellDamage
Re: 8mm h&r spacers vibrations
Fair enough, I had a look earlier and tried mounting one of the 8s. No wonder they cause wheel vibration, there's literally nothing for the wheel to sit on, not to mention the increase in radial loading in the bolts can't be good for them?
Cheers for the part number.
- Mr Footlong
Pretty sure I have seen this discussed before but.....
Any arch rubbing front/rear with the 8/10 kits?
Other than mild aesthetics, any other reason for the spacers?
Thanks.
Thanks.
Current:
Gone:
Gone:
yes exactly thisCellDamage wrote:Fair enough, I had a look earlier and tried mounting one of the 8s. No wonder they cause wheel vibration, there's literally nothing for the wheel to sit on, not to mention the increase in radial loading in the bolts can't be good for them?
no rubbing and i was low, Increasing track width (not wheelbase) = REDUCING the total amount of lateral (side/side) weight transfer. Negative effects include increased stress on wheel bearingsMr Footlong wrote:Pretty sure I have seen this discussed before but.....
Thanks.
CellDamage
Anyone want to buy a set of 8mm non hub-centrics for the front? They don't cause wheel vibration, promise
- Virdee Autos
- Trader (Expired)
As always we have the correct bits all in stock
Fit and forget!
Fit and forget!
Virdee Autos ~ 07950-526592
Daytona RS
AgreedRick_RS4 wrote:yes exactly thisCellDamage wrote:Fair enough, I had a look earlier and tried mounting one of the 8s. No wonder they cause wheel vibration, there's literally nothing for the wheel to sit on, not to mention the increase in radial loading in the bolts can't be good for them?
Thanks.
- Mr Footlong
Got the kit from Virdee. Fitted today. Not sure what all the fuss is about after fitting them tbh and not cheap, but you can't fault the quality of the spacers, absolutely DEAD on machining
Current:
Gone:
Gone:
Have exact same problem bought coilovers then spacers non hubmetric and the vibrating is driving me insane, so ive just text virdee to get full new set ordered up
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 342 guests
