Cost of disks and pads
3.0 V6 24v TFSI - 329 bhp
S4WON
Post by S4WON » Sun Mar 09, 2014 10:33 am
Hi all
I'm seeing a 4 today, possible negotiation point is disks and pads. How much should I expect to pay from a stealer?
Batfinnk
Re: Cost of disks and pads
Post by Batfinnk » Sun Mar 09, 2014 3:13 pm
Just had a quick look on ECP and they are listing front pagid discs at £29 each for the front and front pagid pads for just under £60 a set. Bloody cheap!
Previous car: 2005 S4 B7.
S4WON
Post by S4WON » Sun Mar 09, 2014 3:21 pm
Batfinnk wrote:Just had a quick look on ECP and they are listing front pagid discs at £29 each for the front and front pagid pads for just under £60 a set. Bloody cheap!
Wowzers! Unexpected and a lot better than my b7 rs4!!!
Maybe I'll settle for 500 quid supply and fit from a stealers
Batfinnk
Post by Batfinnk » Sun Mar 09, 2014 3:27 pm
And half the price of discs for my B7 S4! That seems like a lot tbh. I would fit them myself and save a fortune in labour.
liffy99
Post by liffy99 » Sun Mar 09, 2014 6:14 pm
£29 per disk - are you sure ?
Flip pin' ECM - I'll use them as crockery.
Disks on the old 3.2TT were £400 odd.
Batfinnk
Post by Batfinnk » Sun Mar 09, 2014 8:12 pm
I put in the car as a 2010 S4. Checked the spec on the actual disc page and came up as 345mm which I believe is the right size..
liffy99
Post by liffy99 » Sun Mar 09, 2014 10:30 pm
How do you know which is correct ? I put my reg. in, it came up with the right car, and it listed discs with different diameters. It also listed disks with the same 345mm diameter several times. For example there are two Pagid disks available, one more expensive than the other ( and there are Bosch and others available). Why do you think it's the £29 one and not the £39 one . . . .
Batfinnk
Post by Batfinnk » Sun Mar 09, 2014 10:44 pm
I just picked the first one on the list as an example. The correct ones specific for the car may vary from what I picked but was just trying to give a rough helping guide prive wise :)
liffy99
Post by liffy99 » Sat Mar 15, 2014 12:40 am
You were right - I checked with ECP. Fantastic price at less than £60 a pair and I've not heard any bad reports of Pagid. Might order a pair for the future. I was expecting two or three hundred quid :beerchug:
