light and strong Audi R8 V8
Models: V10 plus, GT, GT Spyder, V8 Limited Edition, Exclusive Selection Edition, China Edition and LMX
4.2 V8 32v Naturally Aspirated - 414 bhp (2007-2011) - 424 bhp (2012-2014)
5.2 V10 40v Naturally Aspirated - 518 bhp (2012-2014) - 542 bhp (Plus 2012-2014) - 562 bhp (LMX 2012-2014)
5.2 V10 40v Naturally Aspirated - 533 bhp (2015-)
5.2 V10 40v Naturally Aspirated - 602 bhp (Plus 2015-)
adsgreen
Re: light and strong Audi R8 V8
Post by adsgreen » Tue Mar 04, 2014 4:46 pm
OMG
so what you are saying is after all this intake and exhaust work it's simply been bolted on with no mapping and it just explodes through the roof?
Speedr8
Post by Speedr8 » Tue Mar 04, 2014 5:09 pm
Hi
no, it was only subsequently changed the MAF and filter and now the exhaust system.
The engine ECU can adapt easily without which there is damage. :bigblink:
Tom
Post by bam_bam » Tue Mar 04, 2014 5:13 pm
Can someone please pass the salt...
RIV
Post by RIV » Tue Mar 04, 2014 5:39 pm
What's wrong with the pepper??
adsgreen
Post by adsgreen » Tue Mar 04, 2014 5:42 pm
Speedr8 wrote:Hi
Tom
no it can't. not that amount.
Speedr8
Post by Speedr8 » Tue Mar 04, 2014 5:52 pm
Hi
Enrichment can + 25% without the ECU needs to be changed
Tom
adsgreen
Post by adsgreen » Tue Mar 04, 2014 6:02 pm
Speedr8 wrote:Hi
Tom
It's a lot more than just fueling.
Post by bam_bam » Tue Mar 04, 2014 6:21 pm
You like pepper on your popcorn, are you retarded?!?!
RIV
Post by RIV » Tue Mar 04, 2014 6:33 pm
No way!!!! I like cayenne pepper :FIREdevil:
Speedr8
Post by Speedr8 » Tue Mar 04, 2014 6:46 pm
the lambda control can compensate
Tom
adsgreen
Post by adsgreen » Tue Mar 04, 2014 7:56 pm
Speedr8 wrote:the lambda control can compensate
Tom
And the timing and the cam advance?
Put this way, your 411ps wheel horsepower isn't that far off some very early supercharged installs.
Now they may not have been the greatest things ever fitted but the claims here are that just changing exhaust and intake components you suddenly get without any other messing about an engine that is as nearly volumetrically efficient as forced induction.
Speedr8
Post by Speedr8 » Wed Mar 05, 2014 7:52 am
Hi
I do only classical engine optimization as it was carried out formerly.
Audi constructed the engine and adjusted it to 420 PS.
The engine has more potential and I use this.
Tom
adsgreen
Post by adsgreen » Wed Mar 05, 2014 1:47 pm
Speedr8 wrote:Hi
Not sure I agree with this - this isn't a turbo engine that is easily tuned to whatever (within reason) you want. Granted, they would have had a target specification but it's a bit trickier with N/A
Even with the RS5/B8 RS4 the extra power comes from extending the rpm range and extra 250rpm with slightly better high speed breathing.
Consider this dyno comparison
This is classic N/A engine performance. The B7 RS4 is compromised on low torque (as the S5 simply spanks it) as it is a compromise between top end power and low torque.
Ironically what you need to flow air at high speed is completely the opposite really low down. You can see once 5500 rpm appears the RS4 just carries on where as the other engines fall away.
But the implication is that the engine is crippled but at 100 bhp/litre from a big v8 that's not what I'd call overtly limited.
Now yes, I do agree the engine has a lot of potential and if I had the time I'd love to open up a v8 and have a play with it. But I'd be thinking headwork and cams not just for what is really an airbox and exhaust.
Speedr8
Post by Speedr8 » Wed Mar 05, 2014 3:48 pm
Hi
In the RS5 engine, the cylinder heads were from Audi, provided with the outlet and inlet channels of the V10.
The individual channels of the intake manifold were also designed larger, but
Unfortunately, shortly after a taper throttle flaps (space for oil filter).
The exhaust manifold 4-1 from the RS5 is good, but the catalyst after
600 CPi is (ceramic) bad.
The camshafts are easily the RS5 preturned in the control period,
but make the same stroke as the RS4 B7.
These are the changes to the RS4 B7 will give the RS5 the extra power.
@adsgreen
I invite you to be my appointment on 04/12/2014 at JDEngineering in Hanzeweg 22, 7241 CS Lochem Holland here.
At 11 clock is the time.
It is also possible, which is the RS4 B7 present
Tom
adsgreen
Post by adsgreen » Wed Mar 05, 2014 4:59 pm
And yet after all those changes between the RS4 and RS5 the torque is still the same...
Forgive me if politely decline travelling to Holland on what I believe to be a complete fantasy.
Return to “R8 Coupé / Spyder (Typ 42) 2007-”
