new battery time!!
rocket1
new battery time!!
Post by rocket1 » Tue Feb 18, 2014 10:29 pm
my car has been sorned for 3 months and after various winter jobs its back on the road for 1st march. however i think a new battery is due as had to jump start the car a few times and have charged it 2 weeks ago but it lost power again to the point that not even the interior lights up on door opening. ive crossed reference batterys and think i need an 019 or 019 agm. can anyone confirm what they bought if changed recently. thanks guys!!
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
cheesyslug
Re: new battery time!!
Post by cheesyslug » Wed Feb 19, 2014 12:44 am
Hello mate, I recently changed the battery in my 2007 b7 rs4,i also thought I needed a 019 but turned out the direct replacement was an 020. I went for the bosch silver s5, direct fit.
http://www.justcarbatteries.co.uk/index ... s5015.html
MB2
Post by MB2 » Wed Feb 19, 2014 11:03 pm
I bought one from Halfords as I thought the original was sluggish probably wrongly. It looked too small but was what they recommended and had a long guarantee it has been fine for several years was a Bosch.
sckrs4
Post by sckrs4 » Wed Feb 19, 2014 11:31 pm
Which battery?
019AGM or O20
See below page 41
http://jci_media.s3.amazonaws.com/varta-automotive/7713/5765/6039/VARTA_Catalogue_Automotive_UK.pdf
Looks like it depends on electrical options
Bosh seems good with 5 year warranty.
Could anyone confirm?
Thx
Post by MikeFish » Thu Feb 20, 2014 12:44 am
That top of the range Varta battery is rated at 95ah and 850CCA. How does that comapre to the OEM battery? Mine is obviously getting old and only takes a short time with all my amps on to drain it (even on low or zero volume) so would like a new one that is a bit of a tough cookie.
sakimano
Post by sakimano » Thu Feb 20, 2014 7:09 am
Ours is 850CCA I believe. And 61lbs
sckrs4
Post by sckrs4 » Thu Feb 20, 2014 9:50 am
Isn't Verta an OEM battery?
sckrs4
Post by sckrs4 » Thu Feb 20, 2014 10:17 am
cheesyslug wrote:Hello mate, I recently changed the battery in my 2007 b7 rs4,i also thought I needed a 019 but turned out the direct replacement was an 020. I went for the bosch silver s5, direct fit.
Hello there,
Just wanted to check, the link you posted was it a good fit on your RS4 B7?
Not sure if I should go for Bosch or Varta. Varta seems to be an OEM.
Bosch Spec:
S5015 020 BOSCH
12V 110Ah
5 Years Guarantee
Voltage - 12V Capacity -
110Ah
CCA (EN) - 920A
393L x 175W x 190H
UK code 020
Varta
12 volts
39.3 x 17.5 x 19 cm
Manufacturer Part Number I1
Voltage 12V,
110Ah,
CCA 920
Supplied with 5 Years Warranty
UK code (020)
Varta code: 610 402 092
Price range from £87 to £128
rocket1
Post by rocket1 » Thu Feb 20, 2014 9:14 pm
ended up buying the bosch s5 020. bought it from euro car parts via ebay and collected from my nearest branch. £115 but would have been £135 if bought over the counter. 5 year warranty too. will change over at weekend. 8)
cheesyslug
Post by cheesyslug » Fri Feb 21, 2014 4:02 am
Hello there,
Bosch Spec:
S5015 020 BOSCH
12V 110Ah
5 Years Guarantee
110Ah
CCA (EN) - 920A
393L x 175W x 190H
UK code 020
Varta
12 volts
39.3 x 17.5 x 19 cm
Voltage 12V,
110Ah,
CCA 920
UK code (020)
Hi mate,
The bosch was an absolutely perfect fit in my b7 rs4 avant, identical in size to the oem (which I think was a varta) that it replaced. Even the covers for the terminals were identical, but silver :-) Beware it's VERY heavy.
The link I provided was for reference, I actually got it from Halfords (£160!! was desperate as was having electrical draining issues the day before Xmas eve which turned out to be nothing to do with the battery - a story for another thread - but I figured the 6+ year old battery was maybe past its best) 5yr guarantee too. :thumbs:
The model number is the same as in the link. Hope that helps you mate!
sckrs4
Post by sckrs4 » Mon Feb 24, 2014 11:26 am
Did some research into the battery and Varta came out the best. Even Audi gets the same on replacement.
Anyway, got the battery from http://www.tayna.co.uk/ which was around £90 for I1 (Varta code: 610 402 092) and next day delivery.
Made a big difference and all the electrical circuits are handing power very well. Most noticeable was on RS4 RNS SatNav you do get this flicker at times, but all those have gone.
Highly recommend the above company if anyone is thinking of changing the battery. Mine was around 8 years with the OEM battery !
Users browsing this forum: Google Adsense [Bot] and 314 guests
