RS4 B7 Disc Life Poll
Re: RS4 B7 Disc Life Poll
I'm on less than 25k (from new) but they'll certainly exceed that. Your numbers are way outside normal wear & tear..
2007 Daytona RS4 Avant
Changed my fronts at about 45k I think.
i'm about to change mine this spring and I'll have about 37K at that time. These are the OEM's that came with the car (first brake change!).
I need to change all 4, so I'm thinking they wore more from the EDC (heavy, slippery winters) than my driving. I down shift a lot too.
I bought the LW 380mm upgrade from JHM - can't wait to try them.
I'm in Canada BTW.
I'm in Canada BTW.
2007 RS4 | Sprint Blue Saloon | Silver Nappa and Brushed Aluminum | Premium Package | ECS Wheel Spacers | 1,000 W Pioneer sub and Kenwood amp | Canadian car
Iain_S4 wrote:80K on the original set. Car on 111K and second set looking ok
Is this miles or kilometers... ? lol
Interesting, how many of you guys are heavy braker's over down shifters or both?
2007 Sprint Blue RS4 (B7) Black Optics, Solar Sunroof
i have to do both to stop!ASH555 wrote:Interesting, how of you are heavy braker's over down shifters??
sar wrote:i have to do both to stop!ASH555 wrote:Interesting, how of you are heavy braker's over down shifters??
Its miles. I do 250 miles a week commuting that is typically easy on the brakes as I tend to use engine braking a lot. I went through 3 sets of brake pads for the original front discs.SoaRS4 wrote:Iain_S4 wrote:80K on the original set. Car on 111K and second set looking ok![]()
I almost got 100K out of the rears. I was trying but in the end they were pretty shot and I had to replace them just short of thattoyneg wrote:I just went through the paperwork and my fronts were actually replaced at 33k but this set is still going at 93k - I can't find any record of the backs being done, surely they can't last that long? Obv ots now time to replace them all
- Graeme4130
I got about 20k out of a front set on my old B7
FWIW, B8 uses rear brakes to assist with stability/traction control, so my rears are now looking ready for a change soon on 16k
16k from your rears.....yikes that ain't much! How are the fronts holding out?
- Surrey Sam
lengster1 wrote:16k from your rears.....yikes that ain't much! How are the fronts holding out?
Replaced due to squealing issues IIRC.
I bought my car with what I think were the factory discs. They lasted over 40k. The second, third and maybe fourth set lasted no more than 4k each. I had them replaced under warranty each time. After much mud throwing by the dealership and Audi UK I finally got a fix in the form of ceramic discs which are fantastic. It wasn't easy though.
- Graeme4130
Yeah, front discs, calipers, pads and carriers all replaced under warranty due to squealingSurrey Sam wrote:lengster1 wrote:16k from your rears.....yikes that ain't much! How are the fronts holding out?
From what I remember, fronts had worn way less than rears are now
Mine had 85k and were only 70% worn
Maybe less
Maybe less
20-25k mileage range for me, but then I'm not then I do track the car and have been known to drive in a spirited manner.
That's based on 60k miles in 5 years and only last year having a new set of discs. Admittedly, that disc change wasn't necessary as they probably could have gone for skimming.
Pad build causing brake judder is still a PITA though, even with aftermarket discs and pads.
Darren
Darren
Users browsing this forum: Google Adsense [Bot] and 1553 guests
