New B7 owner, prepare to flame for being lazy!
Re: New B7 owner, prepare to flame for being lazy!
Question for any of you guys with updated RNS-e - did you simply ebay your mk1 OEM head unit and if so what would one expect for it, reasonably?
Gone but never forgotten:
PetrolDave - I assume if I have the useless Audi CD changer then the Audi AMi will be a direct replacement - i.e. no glove box part required to accommodate the new Ami - a simple witch over?PetrolDave wrote:neilparf wrote:And the ability to swap out the (useless) CD changer for an AMI and get either a big hard disc or proper iPod compatibility.
- PetrolDave
Physically yes the AMI is a direct replacement (so no mods needed to the glovebox at all), but electrically it totally different so you need a different cable between the AMI and the CD changer - which you can get from eBay or Kufatec amongst other places.neilparf wrote:I assume if I have the useless Audi CD changer then the Audi AMi will be a direct replacement - i.e. no glove box part required to accommodate the new Ami - a simple witch over?
- PetrolDave
AMI and TV are not related in any way.Bladerider wrote:What TV Tuner options are available for what money ??
or is that now an AMI thing ??
TV options? - some places have worked out how to swap the useless Audi analog TV tuner to the digital one.
If you don't already have an OE TV tuner then retrofitting one would be a bug job - you would need to replace some of the glass in the rear to get the TV antennas. So fitting a third party TV tuner is the best option, just make sure you get one that can be controlled from the RNS-E - Kufatec do a package of a TV tuner and an interface.
PetrolDave - that's great - looking now yes, the CD changer is physically the same - easy.PetrolDave wrote:Physically yes the AMI is a direct replacement (so no mods needed to the glovebox at all), but electrically it totally different so you need a different cable between the AMI and the CD changer - which you can get from eBay or Kufatec amongst other places.neilparf wrote:I assume if I have the useless Audi CD changer then the Audi AMi will be a direct replacement - i.e. no glove box part required to accommodate the new Ami - a simple witch over?
Sorry for being blonde - if I remove the CD changer in favour of the AMi that cable from eBay/Kufatec is the connection between the AMi and the RNS-e that is different from the CD changer to RNS-e, right? Cheers in advance!
- PetrolDave
Yepneilparf wrote:that cable from eBay/Kufatec is the connection between the AMi and the RNS-e that is different from the CD changer to RNS-e, right?
- Mr Footlong
Any more info or links sir?PetrolDave wrote:some places have worked out how to swap the useless Audi analog TV tuner to the digital one.
Current:
Gone:
Gone:
- surfpunkian
^ *like* nice meme response sir!
Daytona Grey RS4 B7 Saloon, carbon cleaned, titan alloys, LEDs, deflap manifold and stage 1 map, Bilstein PSS9 coilover set up, 8mm spacers, lowered.
- Surrey Sam
lol...Ian McShane probably did actually say that in Lovejoy.
360mm across with the wheel straightSurrey Sam wrote:What is the outside circumference of the TTRS wheel?
- Surrey Sam
***scratches head***sync24 wrote:360mm across with the wheel straightSurrey Sam wrote:What is the outside circumference of the TTRS wheel?
Cheers Sync.
Probably my rubbish way of explaining it. I was actually after the thickness of the steering wheel which would require you to measure it like you would your own waist, or a ladies bust
I just measured my girth [fnarr, fnarr! ] and it's 11cm
Just so you are clear, make 110% sure that you are buying a wheel from or for a manual TTRS, there are plenty of S-Line steering wheel's out there reporting to be for the RS, these are indeed a lot thinner. Mine is an exclusive one from a TTRS and has smooth leather all round and blue stitching [I didn't mind as I am having some interior re-trimming done this year which includes the FBSW]
Alternativley, some of the better retrim services offer to thicken up the 'feel' of the steering wheel - take a look at royal steering wheels http://royalsteeringwheels.com/ there are also some Polish ebay vendors offering various services. For me, it had to be a genuine Audi part but I am aware of others on here that have taken the alternative route. Also the proper TTRS steering wheels tend to be upwards of 800 / 900 quid where the S-Line ones are around 500 - ebay.de also has a few take a look at this for example - http://www.ebay.de/itm/AUDI-TTRS-STEERI ... 4619abdbf7 - this one has paddles but compare the thumb grips and overall look against something like http://www.ebay.de/itm/Audi-A3-A4-A5-TT ... 19e7810293 [which is quiet obviously a S-Line wheel]
Hope this helps.
Hope this helps.
- PetrolDave
Try http://hazzydayz.com/ or craigyb used to do it I've heard he's gone back to IT. The other person to try is NHN over on tsn.Mr Footlong wrote:Any more info or links sir?PetrolDave wrote:some places have worked out how to swap the useless Audi analog TV tuner to the digital one.
- Mr Footlong
I use NHN thanks but hadn't heard about any mod via him. in convo with him currently so will ask.
Current:
Gone:
Gone:
Users browsing this forum: Google [Bot] and 90 guests
