Not if you have to swap the face plate over Dave.PetrolDave wrote:Swapping from a pre-2010 RNS-E to a 2010+ RNS-E should take you less than 15 minutes - including checking/correcting the coding and clearing any fault codes (if you have BT).
New B7 owner, prepare to flame for being lazy!
- Surrey Sam
Re: New B7 owner, prepare to flame for being lazy!
Looks like this one isn't needing a face plate swith - A4/S4 /RS4:Surrey Sam wrote:Not if you have to swap the face plate over Dave.PetrolDave wrote:Swapping from a pre-2010 RNS-E to a 2010+ RNS-E should take you less than 15 minutes - including checking/correcting the coding and clearing any fault codes (if you have BT).
http://m.ebay.co.uk/itm/271099555354
Gone but never forgotten:
- Surrey Sam
Yes, that'd save a lot of time/hassle and Dave’s original 15 minute estimate would be about right.neilparf wrote:Looks like this one isn't needing a face plate swith - A4/S4 /RS4:Surrey Sam wrote:Not if you have to swap the face plate over Dave.PetrolDave wrote:Swapping from a pre-2010 RNS-E to a 2010+ RNS-E should take you less than 15 minutes - including checking/correcting the coding and clearing any fault codes (if you have BT).
One thing to bare in mind - It's my understanding that the SDS is a firmware hack for those eBay units, so if the car was to ever be updated with later firmware you'd lose the SDS feature; thus requiring a later firmware hack to be re-applied. If you go for an H version RNS-e then it is an SDS compliant unit and should keep the feature regardless of updates.
Yes Sam - I knew that would be a firmware hack - but that's interesting on the H version. I kinda had a guy feeling that would be lost on future updates - the guy is gonna throw the SDS in for nothing - however, I'll search further on a H version...
Nice one, Sam...
Nice one, Sam...
G and H is SDS compliant for Euro RNS-e - rest are hacked from what I can tell...
- Surrey Sam
No problem Neil, that sounds about right.
It took me over 6 months to find an H version and the usual channels know that they carry a premium too
neilparf wrote:Ahhhhhh rumbled!!! Sorry Rick - I've been flat out and the camera and upload has escaped me - promise it'll be sorted tomorrow. Forum promise...
cross your heart
I'll eBay my children, Rick if I don't!
30 mins on eBay and Google confirms that, Sam! Bugger.Surrey Sam wrote:No problem Neil, that sounds about right.
SDS - mmmm, with Bluetooth Siri via the microphone it's somewhat more intelligent. But the SDS currently is archaic; but I guess it's how you use the RNS-e daily and if SDS figures in to that...
But my OEM mantra kicks in and a hacked non H would be a bit void for where I want my RS4 wants to be...
Enter engineering mode on the RNS-e and rewrite the flash file hack to the RNSE??
Just for you, Rick:Rick_RS4 wrote:neilparf wrote:Ahhhhhh rumbled!!! Sorry Rick - I've been flat out and the camera and upload has escaped me - promise it'll be sorted tomorrow. Forum promise...![]()
cross your heart
http://youtu.be/-QFj1Xhy4cs
- Mr Footlong
A big thank you to Shopp. After I drilled out all the holes in the donor front discs he sent over to me and fitted them today, all brake judder is gone!
Question(s) time guys:
1. I can't stand the metal part on the RS4 standard wheel. I turn in to roads etc one-handed most of the time and for parking etc I do the same. I normally use the bottom of the wheel a lot so the metal drives me mad and I don't use that part of the wheel at all. I am contemplating having the TTRS MFSW wheel fitted, which will include relocating the Sport button to the dash and a new right stalk for all the menu functions. It is strong money (that I should be saving, not spending currently!!!!), is it really worth it? Heart is telling me yes, head is telling me no! I do have a BT kit sitting here that has to be added in too. Do I "have" to do SDS at the same time, will I really use it? Pretty sure I have a H revision 2012 RNS-E
2. I had the time to check the coding on the RNS-E that I put in yesterday and it is way off. I have done a best guess for what the coding should be but can anyone help confirm please. I am going with this so far:
03?91??
1st ? - Treble Speaker Diagnosis/Optical Parking Aid – No idea what the first one is and I have standard front/rear sensors for parking, nothing else.
Sound Characteristic – She has Bose so going with 9 there?
2nd ? – No AMI, no Sirius as not a Yank, no analogue input, so should that be 1?
3rd ? – It has the TV Tuner (not that it is of any use) and it has a cd changer, so should that be 4?
Thanks guys.
03?91??
Thanks guys.
Current:
Gone:
Gone:
- PetrolDave
I reckon it's dead easy, read the coding/adaptation guide on the Ross-Tech wiki http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29 then write down the values in your current RNS-E and just make them the same in the new one.neilparf wrote:I take it any correcting, clearing and coding is straightforward? Pretty savvy regarding these things... VCDS on its way.
- PetrolDave
See http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29 you need 0309114Mr Footlong wrote:03?91??
You also need to set adaptation channel 8 to 255 to turn off GALA (not needed with Bose AudioPilot which is what we have).
- Mr Footlong
Lol, that would be fupping logical and really obvious, should have thought about that thanks, will stick the old lump in tomorrow and see. What I will say is that even before the swap, Vagisil was reporting back that the defunct TV tuner wasn't coded anyway
Current:
Gone:
Gone:
Users browsing this forum: No registered users and 1151 guests
