Turbo options
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Feb 06, 2014 7:23 pm
sweegie wrote:Some tuners will turn up the fuel pressure and change the fuel pump for north of 520bhp :thumbs:
Yep, I reckon that's the way forward, I want to try and avoid another large amount being added to my already HUGE bill if at all possible :boohoo:
amanda1
Re: Turbo options
Post by amanda1 » Thu Feb 06, 2014 7:28 pm
Forget it .......you have committed yourself, just pay the bill like a man and stop boo hooing
We have all done the same ;)
950 nm torque!
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Feb 06, 2014 7:38 pm
Oh there'll be plenty of boo hooing when 'er indoors has to make do with a wet weekend in Rhyl instead of her usual fortnight somewhere hot and steamy.......
sweegie
Re: Turbo options
Post by sweegie » Thu Feb 06, 2014 7:51 pm
Weiß-sechs wrote:Oh there'll be plenty of boo hooing when 'er indoors has to make do with a wet weekend in Rhyl instead of her usual fortnight somewhere hot and steamy.......
The Weiß-sechs summer holiday, brought to you in association with the Rhyl Turkish Baths Company :)
Recycling dinosaurs for fun
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Feb 06, 2014 8:34 pm
I did like the Sun Centre back in the day, is it still going?
Bladerider
Re: Turbo options
Post by Bladerider » Fri Feb 07, 2014 2:06 am
25psi out the box ??
I assume that they are getting some of that from the stock solenoids then because if they are fitted with 1.5bar+ springs then that is fairly mental !!
Do Audi tuners not recommend stepper motor type boost controllers then ?? They would give you finer control I would have thought if you have heftier actuators on your hybrids - I havent done any research on what turbo sizes are on these cars, they cant be very large if they only equate to 5-600bhp with 25lb of boost on a 4.2 litre engine though - in fact this is the thread we were talking about 2860's and 2876's as i recall so pretty weeny really, certainly 25lb would be getting towards their upper edge of the peak efficiency island.
Maybe look at something fairly cheap and friendly like a HKS EVC6 or similar. All these type of controllers give you control by the same amount as the atuator spring again - the idea being you can fit a softer spring so that you get more accurate control percentage wise - so maybe get them fitted with a 1.2bar (18psi) spring and then you can have the boost levels set to 18psi for town driving, low boost at say 23psi and high boost at 30psi assuming you get your reg and pressures up - Bosch 044 would be my recommendation as it will easily flow enough for the power you want, I think they do an in tank equivalent as well if thats how these are designed as standard. As for injectors then the best make are Injector Dynamics and I would be fairly sure they make ones that will fit Audi rails.
Hope that helps.
J.
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Fri Feb 07, 2014 7:09 am
Yep, we were seeing a pretty constant 25psi and spiking higher! Obviously, the ECU didn't like that very much and just went into "limp" due to the constant overboost.
I've heard good things of the 044 so that's looking like a defo and hopefully we can tame the boost today to get somewhere near the 18-20 psi mark.
Thanks for your input :beerchug:
amanda1
Re: Turbo options
Post by amanda1 » Fri Feb 07, 2014 7:15 am
Oh by the way you had best book your weekend in Rhyl before they close the sun center down.......you just might get a bargin ;)
950 nm torque!
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Fri Feb 07, 2014 7:20 am
amanda1 wrote:Oh by the way you had best book your weekend in Rhyl before they close the sun center down.......you just might get a bargin ;)
Haha....it was back in the 70's when I last went there, surprised they haven't pulled it down years ago :lol:
amanda1
Re: Turbo options
Post by amanda1 » Fri Feb 07, 2014 10:22 am
Well it's still there .......just!!
http://m.bbc.co.uk/news/uk-wales-north- ... s-25680920
950 nm torque!
sweegie
Re: Turbo options
Post by sweegie » Fri Feb 07, 2014 10:35 am
Weiß-sechs wrote:Yep, we were seeing a pretty constant 25psi and spiking higher! Obviously, the ECU didn't like that very much and just went into "limp" due to the constant overboost.
Yep, your tuner will need to calibrate the N75 controller for the new actuators and spool characteristics for the new turbos. The standard PID settings need tweaked even for standard turbos at high boost, to avoid overshoot during spool.
With a lot of work, you can fit a 5 bar map sensor to these cars, to get correct boost control over 15psi. But when i say it's a lot of work, I really mean it!
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Fri Feb 07, 2014 11:36 am
......sounds like you're in the trade eh?
sweegie
Re: Turbo options
Post by sweegie » Fri Feb 07, 2014 1:50 pm
Nah, I only pimp for fun ;)
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Mon Feb 10, 2014 6:08 pm
Got her back Saturday afternoon :thumb:
Some "spirited" driving on Sunday :FIREdevil:
Back to the garage today :thumbsdown:
After some WOT action yesterday I noticed I'd developed a pretty nasty boost leak, sounded like a hairdryer was on full blast in the glovebox....
Had a quick check but couldn't see any obvious hoses blown off, IC's still all attached etc. so I called an end to the hooning and drove home like a nun.
Left it with them to have a mooch.....
Re: Turbo options
Post by chunky79 » Tue Feb 11, 2014 3:47 pm
Bugger, did you check the air filter box? Wonder if it is seated properly.
Users browsing this forum: No registered users and 126 guests
